2004-07 CTS-V with an automatic?
Old Feb 15, 2011 | 05:47 PM
Droptoplt1ta's Avatar
Default 2004-07 CTS-V with an automatic?
Has anyone done or seen a 04-07 CTS-V with an automatic? I am interested in doing one and think it would be a sweet daily driver. I would assume a 4l60e would be used.... Will that trans even fit?
Please chime in if anyone has heard of this conversion
Old Feb 24, 2011 | 02:08 PM
Dyno paul's Avatar
Default LS2 CTS-V Automatic.
I put a 2007 LS2 4L70E (trailblazer SS transmission) into a 1967 Nova. The harness and computor I bought was the GM Performance Crate engine Harness, However I added the Trailblazer SS . T42 Trans module with this. My initial problem was the Engine module would not communicate with the trans module. The reason is the CTS-V comes with a manual trans.So it does not need to communcate with an Automatic trans. So I changed (Vector Motorsports) the program to trailblzer SS and now it will communicate. I also had to use the matching throttle pedal.
Old Feb 24, 2011 | 04:49 PM
Tainted's Avatar
I wouldnt go 60e but rather 4l80e or if you got the cash a 6l80/90e out of a new cts-v
I've enver seen or ehard of it done, and id like to know more about it as well. Im positive it can be done just not sure with what changes. i know one thing to look into would be the console and shifter from a V6 model as the V's have no auto console so that'd be something that would have to be swapped.
Old Mar 12, 2011 | 01:49 PM
TrueBlueGTO's Avatar
I'm sure the transmission will fit. The CTS shared the same platform as the STS which had the 6L50 and 6L80. I've always wanted to do a 6L80 swap in a first gen CTS-V...but they are still a bit too pricey used. All you would need to do is to have the harness converted for a T42.
Old Mar 13, 2011 | 10:48 PM
itsslow98's Avatar
I know it can be done but its probably gonna be pricey. I have never seen one done. I can assure you that with an auto on a bone stock V, it will be faster then 90% of the modded Vs with 6 speeds.
Old Mar 14, 2011 | 10:55 AM
I was thinking about using a 4l65e or 4l70e with some mods to it. This trans is much cheaper then the newer 6 speeds. If the stock CTS-V PCM cannot be used, I would use and LS1 Vette or Fbody PCM.
I wouldn't go further for bolt on for mods because it would be my DD
Old Mar 14, 2011 | 02:13 PM
What model year is your CTS-V?
Old Mar 14, 2011 | 02:25 PM
I dont have one yet. I am looking into doing an 04 or 05
Old Mar 14, 2011 | 09:32 PM
itsslow98's Avatar
Just remeber with an auto your gonna handicap what the car was built for........turns.
Old Mar 14, 2011 | 09:38 PM
eviltwin_1987's Avatar
Add a second speed sensor to the back of a 4l80e or 4l60e so that the pcm still thinks that it is a stick and run a stand alone tranny controller
Old Oct 29, 2013 | 08:49 PM
LS BRAVADA's Avatar
I know its old. Anyone know the results of this
