water pump issues
Old Feb 23, 2011 | 06:49 PM
xyster's Avatar
Default water pump issues
can someone tell me (yes i have searched) which is the in and which is the out on a 2000 LS1 water pump to go to the heater core or does it really matter?
Thanks in advance
Old Feb 23, 2011 | 07:29 PM
S10xGN's Avatar
Thanks in advance
Search....hmmm, it's been discussed numerous times. Anyways, the small fitting is the pump outlet and the larger fitting is the return.
Old Feb 24, 2011 | 05:53 AM
mikezohsix's Avatar
agreed, and it only matters if the valve you're using is direction sensitive.
