Wiring Harness from Performance Systems Integration PSI
Old Apr 9, 2012 | 07:27 AM
  #141
psiconversion's Avatar
LS1Tech Sponsor
Sent PM in response.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Apr 10, 2012 | 10:47 AM
  #142
ls68firebird's Avatar
I have to give kudos to PSI. I ordered my harness about a year ago, and just now went to put it in. I was having a bad day and couldn't get nothing to work. I came home on Easter and sent an e-mail and got a response the same day - on EASTER! that's customer supporrt! Played phone tag on Monday ( phone service sucks here at work) and then talked to him in the afternoon. He explained my problem and when i went back to the car, bingo- everything went like clockwork. Thanks to Jon and PSI!
thanks
-wade-
Old Apr 10, 2012 | 04:47 PM
  #143
MGGLS1's Avatar
Just got my harness in less than a week! WoW!
Old May 15, 2012 | 10:57 PM
  #144
KDavis04ss's Avatar
Is it possible to do a 2010 6.2 DBW with a turbo 350? Obviously it would be a manual valve body. One company told me that it couldn't be done because the ECU needs to know when the vehicle is moving.
Old May 16, 2012 | 11:03 AM
  #145
LS1Tech Sponsor
The VSS SHOULD be hooked up for proper function of the various tables in the PCM tune. It does not HAVE to be hooked up. We have a TH350 in our 71 Nova with LS2 DBC setup. We just took a 4L60E Reluctor wheel and a tailshaft housing from an aftermarket transmission company and replaced the stock plastic speedo gear. It works very well. Give us a call to discuss your options if you would like.
Jon
PSI
732-691-6531
__________________
Ebay Store
Old May 26, 2012 | 10:47 AM
  #146
DCx's Avatar
DCx
PSI
I am working on a 5.3 swap project. I am yet to source an engine. I will be using a th400 trans. would you be able to build me a harness and pcm that would run the 5.3 on a dbw throttle with no transmission wiring?
Old May 26, 2012 | 11:40 AM
  #147
LILHEMI's Avatar
P
Originally Posted by DCx
PSI
Im gonna go ahead and answer this since john made this exact harness for me 3 months ago. He even put the ls3 maf plug on it for me for a little extra.
Edit **** didnt see dbw on my phone. My **** is dbc. Sorry bout that.
Old Jul 12, 2024 | 07:28 PM
  #148
R70chevy's Avatar
Default PSI Harness
@thenova70ss
How did you like the harness from PSI?
I need one for my LS1, wondering how yours turned out.
thanks
R70chevy
Old Jul 12, 2024 | 08:15 PM
  #149
B52bombardier1's Avatar
This is a twelve year old discussion and you won't likely get an answer from many of these posters.
Rick
Old Jul 12, 2024 | 09:19 PM
  #150
the_merv's Avatar
Veteran: Air Force
You say that, I bet the PSI guy is still hanging out in here.
Old Jul 13, 2024 | 01:54 PM
  #151
LILHEMI's Avatar
Originally Posted by R70chevy
@thenova70ss
thanks
R70chevy
I am running the Terminator X MAX on my Nova now but my old setup with the PSI harness is still up and running. If I was going to go that route again I would definitely use the stuff from PSI.
