wiring madness
Old Mar 2, 2011 | 05:11 PM
accentexit's Avatar
Default wiring madness
i have put a ls1 into a 95 camaro... i have swapped out the engine harness of course and also the interior harness.. i have power to the entire car... however the engine will not turn over... im using the same coulom and key.. all of the interior harness did plug to the coloum but im not getting power to the starter.. Dose anyone know the route that power goes from the ignition to the starter? any info would greatly apperciated.. this is a 2 yr project and this is the only thing holding the car back from starting.. PLEASE HELP lol... thanx
Old Mar 2, 2011 | 07:13 PM
red 95 t/a's Avatar
You shoulda just used the ls1 engine harness and the 95 dash harness and repinned some wires thats what i did its alot easier. Took me 2 nites to wire my car.
Did you use the ls1 dash harness fuse box? Sounds like sumn with the vats(chip in the key) But it should crank. Ignition switch on the colum is prolly diff.
I would swap out the ls1 dash harness and put the lt1 back in. That way every thing inside would work. I think i moved around 10 wires In the ls1 engine harness and it was running.
Go on lt1swap.com lotta info on there---search Ls1 into 95 camaro on here----or search a guy on here screen name the merv he helped me alot
