steam vents?
I'm trying to keep the engine compartment as clean as possible and a hose to the water pump would be less clutter than to the radiator.
[IMG]
[/IMG] Scott
the 4 ports on the front/rear of the heads are for heated coolant to leave the heads; so any of those places will be fine. I would have done the tstat housing for the same reasons (ease of tapping/cleaning/etc) but my radiator has the inlet for it stock (some wip shots in my ta thread in my sig)
definitely post some pics as you go along, one of my friends/mentors did a variant of a stalker and its one of my favorites
Scott
Tails
Andy1
It will trap air and hurt cooling flow through the engine. Turns out I need a high point in the cooling system to run a line from the steam tubes in the cylinder heads to. And I used this to make that happen.
It's from Jags That Run. It has an inlet/outlet size of 1-5/16", a bleed valve and a barb fitting for the 1/4" ID hose from the steam vent. I cut the hose where I wanted the splice to be made and installed one half.
Then the other half and routed the steam vent line.
Doesn't look half as frankensteined as I thought it would. Plus it will be functional.
We designed the part as small as possible because of the limited amount of space with many engine swaps.
Also, we make these parts inhouse, with our own equipment (CNC lathe and CNC vertical machining center). We use thread gages to verify the npt threads are the correct depth.
There are similar products sold on ebay (and made in China), but they are bulkier, and the npt threads do not meet the gage standards.
Furthermore, when you factor in that the parts on ebay don't include the fittings, our part is less costly to purchase. I mention this because there have been other threads where people purchased something on ebay because of the perceived lower cost.
