How to remove ECU connector pins?
Specifically the fuel level wire & the fuel tank pressure sensor wire - they are cut right at the connector to the point that I can't even butt-solder a wire onto them.
This is the large red & blue connectors that go to the GM ECM on an f-body in my specific setup.
Is there any tool or method to remove these pins and buy replacements w/wires or simply remove these and remove another one that i'm not using for my swap and replace the ones I need - IE move a longer wire + pin into that position?
I searched around and I know a number of other cars have pin-removal tools and what not but couldn't find anything for the lsx setups. Could anyone shine some light on this for me?
thank you
First remove the Gray cover on the back side. 3 tab on each side.
Once the colored covers are off, Use a pick to push the white locking tab away from the pin (what locks the pin in) so that then pin/wire will slide out. You can either pull or push them out.
Once you do that, the pins will just slide out if you push or pull the wire/pin. Might have to use the pick to push the white locking tab on the pin side away so that pin/wire will slide out;.
http://www.repairconnector.com/produ...-3-Pieces.html
Mike
