Should an automatic valve body th350 manually shift normal with no vacuum source.
The th350 I am running behind the lq9 is a built trans but does not have a manual valve body. I totally forgot to hook up the vacuum modulator. Today when I took it for a cruise it would not shift correctly even with me manually shifting. It did go into second a couple of time part throttle, but sometimes it wouldn't and it never went into third (although my max speed was only 30-35mph so that might have something to do with it)
I was under the impression that the trans would shift fine manually even with no vacuum source (even with a auto valve body), is this incorrect? Does it need vacuum source for part throttle manual shifts?
