LS1/T56 in 1997 E36 M3 - Samberg kit
I sourced an LS1 out of a 2002 Trans Am with 35,000 miles, and a T56 from a 2000 Camaro which came with a new Ram clutch kit, resurfaced flywheel, and remote bleeder (got lucky on that one
).I picked up an E36 in December with plans for doing an LS1 swap. The 1997 S52 runs great, with all of its 185,000 original miles. I already have a buyer for the motor and trans, so that helps.
I will be dropping off the headers to be ceramic coated, and I will probably end up powdercoating the subframe and mounts. The turnaround time is about a week, so I won't be tearing the car apart until I get everything back. Next thing to do is to buy a cam with springs and pushrods. I am thinking of a 224/230 cam, as my local reputable LSx shop recommended. They are telling me that they get good results with that cam throughout the RPM range.
Enough typing, on to the pics:
The E36:
Out with the old:
3/11/11 Sourced LS1 from stock 2002 Trans Am:
The nasty motor (battery exploded in the front end collision). It started right up and I was able to hear it run.
3/11/11 Sourced T56 w/Ram Clutch, Light Flywheel, Remote Bleeder, Hurst Shifter:
3/16/11 - The Samberg Kit Arrives:
Yes, they did a great job on the ceramic/powder coating.
It should be running in the next few days, then finish up the small things. This weekend, I worked on my stage 1 weight reduction and had an appendectomy performed (yes, seriously). When it comes to weight, everything counts
Needless to say, I won't be getting any videos up anytime soon. I am still recovering, and the shop that is working on the car is waiting on parts.
Also trying to find a 3.91 LSD for the rear and ordering subframe bushings for the rear.
That is my excuse for now!
Seriously, good luck on the recovery. Hope things are going well for you - and the car.
Oh man, where were you on Friday? I could have used your wisdom
you still have two piece driveshaft? Any special reason for this?
