My wiring harness build thread
Harbor freight has shrink tubing in bulk rolls for minimal out of pocket along with 10 packs of tape
For your solder, be sure to use resin core in whatever diameter you feel comfortable with. I use the .062" 60/40 stuff in 1lb rolls. You should never have to worry about getting too much solder on a connection. Just touch the iron to the joint and the excess should transfer over. For the 18-20ga stuff it doesnt make a huge amount of difference anyway. If the iron is hot enough, the first touch should flow all the solder in you would need
Oh, and be sure to double check each wire with a meter prior to wrapping it up into the loom. It is 100x easier to fix an bad connection right after you made it than to have to trace it out in the sea of spaghetti
Now I need to buy a good used oil pressure sensor connector, I need to buy a good used IAT sensor with connector, and I need color pics of '02 L59 cam position sensor connector with wire colors visible, and I need color pics of '02 L59 MAF connector with wire colors visible.
The computer may have several wires coming out of it that are yellow with black stripe, but each of those has a number at the computer. With lt1swap.com, you can find out which number goes where. Then you can make labels and stick them on each wire.
Blue 21 is yellow with black stripe, and goes to the crankshaft position sensor.
Blue 37 is yellow with black stripe, but goes to injector 6.
There's no way to confuse an injector with a crankshaft position sensor.
It's either this, or spend hundreds of dollars more buying one.
This way, you learn more, you gain skills, you save money, you get something new to break the monotony of being a couch potato. It's all good.
You should tackle it, rather than talk yourself out of it.
If you do hit snags, there's lots of free help available. And what's life without challenges?
I can think of many challenges for which there's no help available. This is way less risky.
Early tomorrow morning I'll be rested enough to attach an empty 4L60E case, s I should get more pics up tomorrow night.
So next was sorting the 2 yellow wires with black stripe. I found 2 of them in the connector at the trans. Luckily, I had this book from the last time I rebuilt this trans:
But this time, I added notes for future reference ( next week )
Problem solved.
So I bundled the wires on the easier side, and then shot 3 pics. But one came out blurry, and one makes it look like they're against the EGR tube when they're not. Anyway;
Then I got online looking for EGR plugs, since my '02 PCM doesn't need the EGR, and when I found some, I did this:
It looks much cleaner, and now that the chaotic "spaghetti" has become neat and orderly, I feel better. Now, on to the more challenging side. Pics this evening.
I'm putting a LS into my 91 corvette. I have a harness and computer from a 99 Z28. I looked at pocket's thread several times and am working up the courage to do it myself. Thanks for the informative thread.
Two ways of solving the issue much like the out the top vs out the bottom engine removal method
Just my process and shows there is more than one way of skinning a cat. In the end. my harnesses arethe diameter of my thumb and is reliable and quick to re-work.
