crankshaft position sensor wire
Old Mar 18, 2011 | 07:27 PM
leon phelps's Avatar
Default crankshaft position sensor wire
Would anyone have a photo of how they got the wire from the harness down the engine to the sensor?
I am not thrilled with the way mine is routed. I have it next to the plug wire.
thanks in advance.
Old Mar 19, 2011 | 06:52 PM
BelAir1000's Avatar
I plan to route mine down the right side bell housing with the starter solenoid and r/s knock sensor wiring. I am referring to a 07 L92. Not sure if they're all the same. I plan to wrap the wires with the metallic heat tape.
Old Mar 19, 2011 | 08:21 PM
that may be a plan, heat tape.
thanks.
Old Mar 19, 2011 | 08:58 PM
Pocket's Avatar
Like this, no heat tape
Old Mar 20, 2011 | 06:09 AM
you mean try not to use the heat tape or you are not using it Pocket?
Old Mar 20, 2011 | 08:13 AM
Old Geezer's Avatar
Thumbs up X2..
how I did mine. I ty wrapped the entire wire bundle to the starter. keeps it away from the exh.
Old Mar 20, 2011 | 08:33 AM
scatillac's Avatar
Thumbs up X3
Heat tape is like beer: You can never have too much , but you can have not enough.........
Old Mar 20, 2011 | 10:42 AM
Pocket's Avatar
No heat tape. At its closest, the bundle is still over an inch away from the exhaust. Even if it was laying on a primary tube, it still shouldnt ever get above the heat rating of the split loom unless the engine was running lean causing the headers to glow
Old Mar 20, 2011 | 10:18 PM
gMAG's Avatar
Me, too.
