How do i convert my ls2 gto to speed density instead of MAF
Old 03-18-2011 | 09:26 PM
firehawk68mcleod's Avatar
Default How do i convert my ls2 gto to speed density instead of MAF
what do i need to buy and wats the cost of the parts i need( estimated ) thanks
Old 03-18-2011 | 10:27 PM
pdsq98gt's Avatar
Hptuners or efi live. If you completely ditch the maf, you need to wire in an intake air temp sensor.
Old 03-18-2011 | 10:56 PM
what would you reccommend to do..... and how would i wire in that air temp sensor
Old 03-19-2011 | 02:05 PM
Irish350's Avatar
hire a tuner
for the IATS you can install one inside your intakes bellows (however you may have it setup)
usually an initial tune is a few hundred bucks for a dyno tune.
Old 03-19-2011 | 08:54 PM
TTLS1GP's Avatar
Go to DIY autotune and pick up a IATS and pigtail. $30
Find a good spot to drill/tap/install it.
2 Wires out of the maf harness (5 total) are the IATS wires. Determine these by the specific pin-out diag for your harness.
Swap out your current MAP sensor with a cobalt 2 bar map sensor from "frost" or the generic 3bar sensor (will need to de-pin and rewire). ~$80
Get a tuner or tuning program (tuner recommended if you don't know about tuning in general) and get the proprietary software installed. $400+ for the tuner or ??? for a dyno tune.
Old 03-19-2011 | 10:57 PM
S10xGN's Avatar
Sorry, why would you change the MAP to a 2 or 3 BAR? OP never said anything about a blower. All your doing is losing resolution by (needlessly) increasing the range...
Quick Reply: How do i convert my ls2 gto to speed density instead of MAF
