New mechanical speedometer drive solution
Old Apr 11, 2013 | 11:02 AM
  #281
dusterbd13's Avatar
no on the aftermarket at this time. stll using the stock 64 gauges. ive been dabating autometers or speedhuts, but would really like to retain the factory stuff.
anyone have a good how to on the guts swap?
Old Apr 12, 2013 | 10:28 AM
  #282
supergeess's Avatar
I am considering a guts swap also. I've got a 77 Jeep Cherokee with 6.0/ 4L60E and posted this question on a Jeep forum, but not much replies yet. Any help with new gauge internals swap into original gauges would be some good info., as I am sure there are a lot of people out there interested in this. I know there are vendors who currently do this at a high cost, but I don't think any of them will chime in and give their secrets away. I don' think it is that complicated. It will just take time and patience.
Old Apr 12, 2013 | 09:44 PM
  #283
71403's Avatar
Pretty much a trial-and-error process that is governed by the amount of room you have to work with. Early/mid 90's GM full size vans have a very compact round electric speedo with the electronics integrated.
Old Apr 13, 2013 | 12:05 AM
  #284
jbsjunk's Avatar
Doesn't Classic Instruments do retro fitting? It may not be cheap, but you can keep the classic looks and feel of the old with new technology.
Classic Insturments
Old Aug 22, 2013 | 06:37 PM
  #285
ModMuscle's Avatar
I hate hijacking threads but felt this was worth it. I am selling my Shiftworks tailhousing if anyone is interested it is listed in the advertising sticky at top of this forum. Hopefully it will help one of you out.
Old Aug 31, 2013 | 11:49 PM
  #286
3rdGenLS's Avatar
Man, I read this whole post and still nothing.
Old Sep 5, 2013 | 01:07 PM
  #287
supergeess's Avatar
Yeah...nothong. I ended up going with a Dakota Digital set up.
Old Oct 22, 2013 | 09:32 PM
  #288
Jdub928's Avatar
Originally Posted by SUPERBOOST
Yes, I talked to him too.He said it was out of stock and put me on a list to call.It looks to be a great idea though,much better than the cable x to me .It has a small box that receives the vss signal that you can calabrate no matter what your gear ratio.This box in turn runs a small electric motor that screws directly on the back of your mechanical speedometer and spins it at the correct mph.It totaly eliminates the drive cable,sounds like a great idea to me if they get it done.According to him it will also run a factory tac as well.Looks like it would be an easier and better way to go than trying to run it through an org.speedometer cable.What about it ,any electronic gurus out there?Build it and make a ton of money!
I just ran acrossed this post asking about a speedo motor drive set up. Well i guess it doesn't exist yet... I am a electronics guru, i think I can make one work and fairly cheap too. Ill keep you guys posted and get working on it.
Old Oct 22, 2013 | 11:51 PM
  #289
ls1nova71's Avatar
Forgive us if we don't get our hopes up too high. No offence, but we've all heard that before. I've been subscribed to this thread a long time and still nothing.
I do wish you the best though, and if you do come up with something , keep us posted, you'll be the hero of this thread.
Old Oct 23, 2013 | 07:13 AM
  #290
ishmael's Avatar
Classic Instruments will do the swap but it ain't cheap. And I think that last guru may have been being sarcastic.
Old Nov 18, 2013 | 10:06 AM
  #291
BushyTea's Avatar
I have been watching this thread as I will be in need of a solution like this as well. However, I did see that Digital Dakota gauges has a new product that while not cheap is a good solution.
http://www.dakotadigital.com/index.c...rod/prd886.htm
Old Nov 18, 2013 | 12:48 PM
  #292
supergeess's Avatar
That is a good option if you want to keep stock gauges.
Old Nov 18, 2013 | 02:25 PM
  #293
jbsjunk's Avatar
Agreed. Price isn't too bad either. You can fine tune it on the fly too.
Old Nov 18, 2013 | 04:02 PM
  #294
stevieturbo's Avatar
Looks a lot nicer than the Abbot X piece
Old Jan 6, 2014 | 03:12 PM
  #295
novamatic's Avatar
A real shame this hasn't gone anywhere yet. For those that are interested, I found this kit on ebay that is 1/5th of the price of a tailshaft conversion for a 4l60e.
http://www.ebay.com/itm/700R4-Speedo-ELECTRIC-TO-MECHANICAL-CABLE-Conversion-Kit-Convert-Speedometer-/310709748767?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4857be841f&vxp=mtr
Am I missing something, is this too good to be true? It says 700r4, but this should fit, shouldn't it?
Old Jan 6, 2014 | 07:38 PM
  #296
ls1nova71's Avatar
That kit is for taking the VSS out of a 700r4 and replacing it with the older cable drive set up. A 4l60e from an LS engine has a different tailshaft and you can't just replace the VSS with a gear.
Old Jan 8, 2014 | 03:26 PM
  #297
MikeJTR's Avatar
We have parts that will allow adapting an older style tail-housing to the LSx 4L60-E transmissions so that you can run a mechanical speedometer.
We make the adapters in-house. We left extra material on the 6-bolt to 4-bolt adapter in case you want to drill and tap holes for mounting brackets and mounts.
We have sold these parts for years, but only recently put the pictures on our website.
For more info, see this link:
http://jagsthatrun.com/Pages/Parts_4...g-adapter.html
Old Jan 9, 2014 | 10:09 PM
  #298
tonytone4143's Avatar
This is good to know. Ty for the info
Old Feb 28, 2014 | 05:24 PM
  #299
lutronjim's Avatar
Default Dakota
Dakota says it needs input from VSS. I am looking into a 'connect and cruise' and it needs VSS for PCM and shifting. Some on forum have had problems with shift problems when sharing VSS.
I can't get Dakota to tell me if theirs will work work with speedo output from PCM.
Old Feb 28, 2014 | 09:35 PM
  #300
ls1nova71's Avatar
A cable x will work from the speedo output from the PCM, so I would think this would work that way too. I've had issues tapping into the VSS directly.
