My project, a 1968 pontiac catalina with a C5R 427
#43
Dig it! I'm in the process of swapping a 6.0 with a t76 turbo into my 1970 Impala. Bodies are different but from your pictures it looks like they share the same frame. What oil pan did you use, is it a cut down f-body pan?
#44
I'll try to post all the parts here and update it, as I go.
Motor, tranny, Wire harnish came from Don at slowhawk performance in Bridgewater ma.
*NGK spark plug Advance auto part # 4177
*Rear 3.55 gears from Metal Fabcraft Works (www.fabcraftmetalworks.com)
*Rear control arm roto-joint end 3/4"-16 thread
*Rear brake kit came from Dean at Hotrodusa.com
#47
Wow it's been a long time, ok time to get started again, back feels great.
just for fun I weighed the old tires and drums:
fronts 86lbs each, That's 172 lbs
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0822.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0827.jpg)
rears 72 lbs each, That's 144 lbs
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0820.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0831.jpg)
Totaling 316 lbs, new tires and wheels should be 100 lbs less.
This thing is really on a diet, the old motor block alone weighed about the same as the complete 427 with accessory's.
#49
This is an awesome project. Love the pics and info you put on here. I will be getting a '68 Catalina that belongs to my grandfather sometime in June. It is a 2 door hardtop, 87K original miles, all original, rust free and immaculate interior. Some of the things you are doing, especially suspension-wise, are things I would like to do, so this is good stuff you got here.
I will post pics once I get the car home. Keep posting those wonderful pics!!!
#50
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0872.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0871.jpg)
Tran's member cut for the 3 inch pipe to pass.
the car has been on the lift for a 1 1/2 years, I landed it on roller dolley's today and notice no spring movement in the front
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I used the wrong grease for disc brakes
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
#51
Don't have the parts to keep working on the motor, so today I ripped out the interior. Found many mouse nest, floor not looking bad, just a few spots to cut and patch.
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0920.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0919.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0918.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0921.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0922.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG0923.jpg)
#52
I put an meter on the old sending unit from the tack, it read 121 owms. I have to by a new sending unit because I damage the old one. Tomorrow I'm clean the gas tank again (for the 4th time) with boiling hot water before cutting into it.
#59
Took months to find a set of headers to fit the B-body, problem was clearing the steering links and power steering pump, I only had to love tap 2 pipes to clear things.
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG1034.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG1035.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG1036.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG1030.jpg)
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG1033.jpg)
#60
I had no idea this was going to take me forever to do. I keep finding more body work to do, i have to fix the trunk (holes) before I can mount the gas tank. one day in the future i may have to buy or make body rubber mounts. did a brief search and found none.
I'm putting everything else on hold and concentrate on getting the motor started.
![](http://i664.photobucket.com/albums/vv2/tramminc/IMAG1037.jpg)
