ls-1 painted intake
Old Mar 25, 2011 | 05:57 AM
wanderlodge's Avatar
Angry ls-1 painted intake
I need some help does anybody know if my ls-6 intake can be painted with base and clear or does it have to have engine or high temp paint seems to me it will run quite cool but I do not want to paint if it is going to discolor
Old Mar 25, 2011 | 07:16 AM
46Coupe's Avatar
Mine is in automotive primer right now. All sanded and will be base coat/clear coat.
I have read that it's been done many times. The intake on these engines doesn't seem to get crazy hot, so I would think it would hold up pretty well.
Old Mar 25, 2011 | 09:24 AM
Mike52's Avatar
I haven't painted mine yet but I saved this pic from another site so I could remember what they used to paint this intake. Hope it helps.
Mike
Old Mar 25, 2011 | 09:38 AM
'02TA's Avatar
Regular paint is fine for the intake
Old Mar 25, 2011 | 09:39 AM
thunderstruck507's Avatar
I spray painted mine and it looks fine even after over a year.
Old Mar 25, 2011 | 09:42 AM
98silvermaro's Avatar
same here... regular spray paint for me
Old Mar 25, 2011 | 06:40 PM
BBC632Camaro's Avatar
My dad owns a body shop and I've worked there since I was a kid and I can tell you base/clear will actually hold up to very high temps. We've even painted stoves etc with it where some hot pans have touched it with no problems. Its important to use a good quality Sealer first and we use PPG paint for the base/clear and sealer as well.
Old Mar 25, 2011 | 06:54 PM
bmf5150's Avatar
I painted mine with rattle can,turned out great!!
Old Mar 25, 2011 | 06:56 PM
bmf5150's Avatar
U can see pics of mine here!!
https://ls1tech.com/forums/showthrea...369420&page=11
Old Mar 25, 2011 | 07:12 PM
1Bad2's Avatar
I've painted engines with base/clear no problem. Just make sure you prep it well and use sealer first.
Old Mar 26, 2011 | 10:00 AM
CL2000's Avatar
It will not be a problem! prep it with a red scotch brite pad and warm water and dish soap. Wash it off with water then let it sit in the sun and use rubbing alcohol on it and wipe it dry. If you want to save money you can get a spray can of SEM flexiable plastic primer. I use ppg at my shop and if are going to seal it or use ppg primer over the plastic you will have to buy a few products which are not cheap.
Old Mar 29, 2011 | 09:33 AM
SamHatco's Avatar
Default This is how I did mine
This it what it looks like today with the CAI I made from AirRaid's U-build it kit
Sam
Old Mar 29, 2011 | 10:53 AM
530sx's Avatar
wow that looks fantastic! how did you get the color? I'm guessing it's a candy?
Old Mar 30, 2011 | 03:55 PM
SamHatco's Avatar
House of Kolor Oriental Pearl Blue. Same as the stripes on the car
Sam
Old Mar 30, 2011 | 04:38 PM
the_merv's Avatar
Veteran: Air Force
That looks good..
Old Mar 30, 2011 | 08:55 PM
1972nova's Avatar
mine is base coat clear coat
Old Mar 30, 2011 | 10:14 PM
crankstart's Avatar
graphite grey is a nice color for these.
