Stans 1968 camaro LS swap and other upgrades!
Old 03-10-2011 | 11:53 PM
  #201
bmf5150's Avatar
well i routed the trans lines similar to what the stock car has,take a look.tell me what ya think.
Old 03-11-2011 | 12:00 AM
  #202
bmf5150's Avatar
got some works done today.
Old 03-11-2011 | 12:02 AM
  #203
bmf5150's Avatar
anyone know what line connects here on the rear of the driverside valve cover?where it goes to??
Old 03-11-2011 | 05:09 AM
  #204
tsnow678's Avatar
The PCV goes there. You are missing the rubber grommet. And as far as where it goes, I would say a catch can and then onto the throttle body. Look around on LS1Tech for some threads on this subject and a catch can will prolly be the route you will want to go. Poor baffling in the valve covers allow oil to be pulled into the throttle body, intake, cylinder heads and eventually into the combustion chamber. The oil that gets into the combustion chamber builds up on the piston and ends up causing the rings to stick which in turn burns more oil. Catch can is the best preventitive, get a sealed unit with internal baffling and a drain.
Looks like you got the transmission lines out of the way! When my car was an automatic I didnt want to spend the money for new factory lines so I ended up bending some out of 3/8" hard line and man the hose you used would have been so much easier and probably better. Looking good!!! I guess I need to get busy as you are fixin to pass me on the build progress. I did get my drive shaft in yesterday.
Old 03-11-2011 | 07:28 AM
  #205
bmf5150's Avatar
So I still need catch can even though I'm using a ls6 valley cover setup??
  #206
bmf5150's Avatar
Thanks for all your help tsnow!!
Old 03-11-2011 | 08:20 AM
  #207
ishmael's Avatar
Where did you get the transmission line set up if you don't mind me asking?
Old 03-11-2011 | 12:17 PM
  #208
bmf5150's Avatar
It's just -6an braided stainless line
Old 03-11-2011 | 03:14 PM
  #209
tsnow678's Avatar
I would say no. Sorry I wasnt paying attention. Some people still want to run a catch can even with the LS6 valley cover. I think the baffling is a lot better in the LS6 cover and its in a better location to pull just pressure and not oil.
Do you have to run a PCV valve with the LS6 valley cover? If so where will it plumb into? Every engine I have owned had a PCV valve.
Old 03-11-2011 | 03:51 PM
  #210
bmf5150's Avatar
I thought PVC valve was in that ls6 valley cover??so do I hook that hole in driver side valve cover over to hose barb on passenger valve cover??
Old 03-11-2011 | 06:59 PM
  #211
ishmael's Avatar
That's too bad, I was hoping someone was selling it already cut and put together. I hate putting the ends on that stuff. I know there's a tool but I'm too cheap to buy one for something I do so rarely. Thanks and keep up the great build.
Old 03-11-2011 | 07:24 PM
  #212
tsnow678's Avatar
There is no PCV in the valley cover just baffling. I have looked around and thats all I can find out anyways. You will need to route the passenger side valve cover breather tube to the inlet on the top of the throttle body before the throttle blade. The drivers side valve cover will need a positive crankcase ventilation valve put in via rubber grommet. Route the PCV valve around the back of the intake and forward up the right side of the intake, run this line either into the vacuum port behind the throttle body on the right hand side or you can buy a catch can and route it there and then from the outlet of the catch can back to the intake vacuum port behind the throttle body. I tried to find this article on here about this but I cannot seem to locate it. If I do I will send it your way.
Old 03-11-2011 | 07:44 PM
  #213
Irish350's Avatar
I still have my old ls6 pcv setup, including the valve - its part of a u shaped tube that exits the crank case cover and enters the intake.
FWIW I had it on my ls1 for like 30k, and still went to a catch can setup, and still think i ran into oil consumption issues.
Going with a bigger can setup on my ls2
Old 03-13-2011 | 07:24 PM
  #214
bmf5150's Avatar
Well looks like I will be getting a catch can set up
Old 03-13-2011 | 10:26 PM
  #215
Steve68's Avatar
Great idea, that ill keep the oil in the can instead of going in the intake,
Old 03-13-2011 | 11:03 PM
  #216
tsnow678's Avatar
I have mine hooked up like it was from the factory just until I get it running. After that I will get a catch can as well.
Old 03-14-2011 | 12:20 PM
  #217
bmf5150's Avatar
tsnow,i will prob do the same thing!
Old 03-16-2011 | 09:07 PM
  #218
futureuser's Avatar
I didn't know you could paint a plastic intake to look that nice. Great job with the build.
Old 03-16-2011 | 10:16 PM
  #219
bmf5150's Avatar
Thanks,just used metallic spray paint and some clear!
Old 03-17-2011 | 11:09 AM
  #220
futureuser's Avatar
Okay, I'm having a good, hard look at your radiator. I put a call in to the number on their website and left a message.
Did you find out for sure if it is a dual pass?
They say heavy duty trans cooler. Do you think it's enough for a 4L80e maybe with a converter?
It looks like from the picture it has the steam tube inlet near the top. Is this the case?
Thanks,
Dan
