LS engine with early transmission
Old Jan 22, 2012 | 11:53 AM
68BBChevelle's Avatar
Originally Posted by 86lxnotch
what year is your lq4? did it come with a flexplate when you bought it?
Its an 2003 and yes i have the plate.
Old Jan 22, 2012 | 11:55 AM
86lxnotch's Avatar
do you know what trans was behind it in its previous life? if it had a 4l80e your good with what you have and only need to elongate the holes so the converter bolts up.
Old Jan 22, 2012 | 12:18 PM
Not sure which tranny it was i know motor came out of a 03 gmc yukon denali.
So if it did have the 4l80e i wouldnt need the spacer? Just elongate the holes? Thanks for the help.
Old Jan 22, 2012 | 12:22 PM
86lxnotch's Avatar
this pic was posted earlier. look closely at it. the palte on the left is what you need, so if yours has a spacer looking piece sticking throuh the flexplate like the picture does your golden
Old Jan 22, 2012 | 12:28 PM
99VetteFRC's Avatar
To help everyone out... You can buy these parts right from your local GM dealer
flexplate 12621399
spacer 12563532
flexplate bolts 12563533 (6 required)
After much research these parts are what is needed to easily bolt an early style trans to a GenIII engine. And as for the design flaws in a 700r4, the rotating internals (clutches, planetaries, drums and spragues) to make the 700r4 as strong as a 4l60e. I use a full manual valve body in my 700r4 and it eliminates the use of TV cable and makes the shifts very firm. Lockup is still used by wiring a toggle switch or an aftermarket kit.
Old Jan 22, 2012 | 12:34 PM
Just went and looked it looks like im good.
Old Jan 22, 2012 | 12:35 PM
86lxnotch's Avatar
good deal, i had been worried about it too. i just elongated the holes and bolted it all together the other day so yea i feel relieved
Old Jan 22, 2012 | 12:36 PM
flexplate 12621399
spacer 12563532
Thanks for the part numbers just looked them up on www.gmpartsdirect.com
Old Jan 22, 2012 | 01:50 PM
lemkerailroad's Avatar
i am glad someone finally put this conversion in pain english
thatnks for the part numbers, now i am going to be ordering them tommarow
Old Jan 22, 2012 | 07:26 PM
99VetteFRC's Avatar
Unfortunatly I was at my local GM dealer in MD Friday and the spacer was on back-order. They did however have the flexplate and bolts in stock. I ordered my spacer from Summitracing.com. It is cheaper in Jeg's but when I called summit they price matched and shipped it to me for $48 complete. Last step before I start my install is the a1000 pump.
Old Jan 23, 2012 | 04:49 AM
68 TT's Avatar
Originally Posted by 68BBChevelle
I just found this on ebay but see no one has bought one yet.http://www.ebay.com/itm/280808029418...#ht_500wt_1287
Zero feedback but the price is good for the flexplate and spacer. It says he includes the longer bolts in the package too so that makes the deal even better.
Might be worth the zero feedback risk to get the parts at that price.
Old Jan 23, 2012 | 05:00 AM
  #32
LSCustoms's Avatar
through gm parts direct
part number 12621399, $50 came with everything wanted and needed, the spacer was already on the flexplate.
however, apparently this is hit and miss, as a dealer will tell you the part number only includes the flexplate... my suggestion is to order it first by itself (even if you have to turn around and order the bolts and spacer, it is still cheaper than the hughes or tci kit...
i went back to the website and noticed they added does not include bolts and spacers, however, I ordered everything separate because of that and had to send the bolts and spacer back at a loss of 20%, and they didnt even want to give a refund because it is special order, made them do it though...
but this is all that came, with the extra parts ordered
if you need to order the bolts and spacer after you check the box to see if they are there then order the following:
#12563532 (1 spacer) $31
and (6) bolts part #19257940, need to order 6 of these part numbers! total of $24
Old Jan 23, 2012 | 05:08 AM
  #33
LSCustoms's Avatar
and just to clarify I ordered through gmpartsdirect and the first part number for $50 came with the bolts spacer and flexplate! even with shipping was lowest I could find anywhere by far. Also the dealer used to sell this in the same manner, because of some recall a while ago, why it was so cheap, they caught on at some point and try to charge separate. I was told it may be hit and miss, but it is worth ordering the first part number and waiting to get the flexplate first to see if the bolts and spacer are there...
even though I ordered it all and got the extra parts, that was still cheaper than the dealer wanted out here for the parts separately by about $100
Old Jan 27, 2012 | 07:56 PM
  #34
Sounds like a great deal to me!
