LS engine with early transmission
It will look like this with the dish flexplate
[IMG]
[/IMG]The flat 6.0L plate has the spacer on the crank side and is flat.
4l80e so long as you use the flat flywheel.
Gen III converter
SBC 700r4 converter note smaller shorter hub
Gen III engines with a stock 4l60/65/70 GM uses a dished flex plate the one on the right note the shorter crank bolts.
On Gen III engines using the 4l80 trans which uses a converter with the Gen I style center hub GM used a Flat flex plate and a spacer mounted between the crank and flex plate. This mounts the TC flush with the center hub.
The flat flex plate is on the left note the longer bolts.
Dished 5.3L flex plate mated to a SBC Gen I 700r4/early 4l60e converter. Note the hub is un-supported because its to short. as well a small torque converter bolt pattern, you have to elongate the holes alittle fot it to line up
Flat 6.0L flex plate and spacer on a SBC converter. Note hub is supported by the spacer. As well has it has 6 bolt holes for veter. So you have to drill new holes to use on the early 4l60e or 700r4/th350 etc...
Where can i get just the spacer and bolts from? Thanks for the help.
Alot more logical and economical as far as a rebuild goes to have a 4l60/e built. I sure wouldn't put a 700r4 behind an lsx without it being fresh.
