"intake hoses" on LS2
Old Apr 4, 2011 | 10:02 AM
magntik's Avatar
Default "intake hoses" on LS2
Ok, maybe a bad title but I'm not sure what to call them. PCV lines, vacuum lines??
Anyway, I put a GTO intake on my TBSS LS2, can someone verify my hose connections?
1. The barb on the valley pan is capped.
2. The barb on the driver's side of the TB, has a hose to the rear of the driver's side valve cover.
3. The big barb on the rear of the intake to my brake booster.
4. The small one (for HVAC) is capped.
5. The barb on the passenger side of the TB has a hose to the passenger side valve cover.
Seem right?
And this thing doesn't run a PCV valve, right?
Thanks.
Old Apr 4, 2011 | 12:25 PM
MrDude_1's Avatar
they all run a PCV valve. ALL modern engines MUST run one... by modern i mean after about 1965 or so... lol
i'll try to find a diagram of the PCV valve location and system
Old Apr 7, 2011 | 08:23 PM
ModMuscle's Avatar
Magntik...I'm doing the same thing as you. I haven't been able to confirm the hose routing as you have stated. The TBSS valley cover doesn't have the connection for the vacuum line behind TB. I don't know if its as simple as attaching Driver Side valve cover to that spot on passenger side of intake or not. The passenger side valve cover connection is to the air intake forward of the TB. What I decided to do is just buy the valley cover that has the PCV connection...attach the preformed hose from my car intake to it like it was designed. I will cap off the driver side valve cover. The passenger side valve cover will attach forward of TB on the GTO K&N CAI I am using.
Old Apr 7, 2011 | 08:41 PM
magntik's Avatar
Originally Posted by ModMuscle
...The TBSS valley cover doesn't have the connection for the vacuum line behind TB.
So whats the connection on mine that's sticking up somewhat angled towards the pass. valve cover?
Where do you plane on buying that from and do you have a part number for it?
Old Apr 7, 2011 | 09:23 PM
ModMuscle's Avatar
Well...I stand corrected. I guess I should have said "Mine does not have the connection..."
Here is the cover I am buying P/N 12599296:
http://cgi.ebay.com/ebaymotors/GM-PN...item3f06d03d17
Old Apr 8, 2011 | 07:33 AM
magntik's Avatar
I never took mine off, partly because I read there was "nothing" under it so to speak and partly because the gasket from the dealership was almost $50.
So I guessing mine looks like that and I should run a hose to it, huh?
But from where?
I didn't get a preformed hose with the intake I bought, where does that one go?
Old Apr 8, 2011 | 07:52 AM
ModMuscle's Avatar
Here is a pic from this thread:
https://ls1tech.com/forums/conversio...nnections.html
Old Apr 8, 2011 | 08:51 AM
magntik's Avatar
damn, that's where my pass. valve cover is connected to the intake! LOL
Old Apr 8, 2011 | 09:01 AM
ModMuscle's Avatar
Passenger side should attach to intake tube forward of the throttle body.
Old Jun 3, 2011 | 01:24 PM
Taylor1969's Avatar
What if I don't want to change the valley cover... I am running a TBSS LS2 also... and I am missing the valley cover tube.
Chris
Old Jun 3, 2011 | 01:49 PM
2Aspire's Avatar
I used this thread to help me with the PCV for GTO LS2
http://www.ls2.com/forums/showthread.php?t=829128
Regards,
Matt
Old Jun 3, 2011 | 02:30 PM
'02TA's Avatar
^ there's good info in that link
