Intermittent DBW problem
Old Apr 5, 2011 | 06:08 AM
fast400's Avatar
Default Intermittent DBW problem
Has anyone run across this problem...
When I turn the ignition to the start mode the DBW throttle blade opens/closes like crazy for 10-15 seconds. Once I start it stops, but the pedal won't be responsive.
I go back 5 minutes later, start the car and the pedal is fully functional...what would cause this??
Old Apr 5, 2011 | 07:18 AM
46Coupe's Avatar
Can you provide more information regarding the components used in your swap?
Model/year of Engine, computer, TAC module (if applicable), pedal, and throttle body?
There is a great deal of information/misinformation about DBW setups and a lot of the information regarding which components will interchange is sketchy at best.
Old Apr 5, 2011 | 02:34 PM
fast400's Avatar
2006 L59 (5.3)....TAC, Pedal, Throttlebody all from the same vehicle
Old Apr 5, 2011 | 05:47 PM
Old Geezer's Avatar
Setting codes?
