Trans PIN out for 99-02 F-body PCM/Harness
Looking to get info on 99-02 Fbody PCM Pinout for Trans.
I looked at the pinout charts in the FAQ.. but wanted to verify I understood what I was looking at and what I need.
All of the Yellow highlighted are for a A4 harness and the Green is for M6 harness.
All of these Yellow / A4 should go to the large round plug in the trans. Does anyone have a Transmission Schematics/diagram so that I can verify also ? (or point me to a Thread / Link.)
Thanks.
Thanks.
![](http://i150.photobucket.com/albums/s98/Pocket_004/LS1%20harness/4L60E.jpg)
Pin S has an error, diagram shows B78, correct pin is B79
![](http://i150.photobucket.com/albums/s98/Pocket_004/LS1%20harness/T56WIRING.jpg)
Eventually Ill draw one for 4L80E's
Just for GP, here are the actual diagrams
http://www.lt1swap.com/pictures/16_a...amp_switch.gif
http://www.lt1swap.com/pictures/17_a4_pnp_switch.gif
http://www.lt1swap.com/pictures/15_c..._switch_m6.gif
Thanks.. I just found that one about 15 min ago.. a bit slow trying to do my research while I am at work LOL.. and I did see that error.. Blue 79 would be the correct one if my searching is right.
thanks, those are the diagrams that I was looking for.
Here is the results of my wiring and findings of what I have / had to do so far.
BC
BC
