65 Impala L99 swap
Bought a L99 outa a 2010 camaro and it came with the wiring harness still all connected minus the ECM.
I see slot of guys buy the GM Performance Parts LS Controller which has a new harness + ECM etc....
Can I just use the harness that came on the engine and pick up an ECM?? Or will that cause me more problems than it's worth?
I have the sneaking suspicion that using the harness from the Camaro is going to be more difficult? Is it just extra connections I don't need?
Thanks!
Does anyone know why the stock harness wouldn't work with out adapting it? Just curious.
Thanks!
I was planning on using the original drive shaft that was in the impala but I don't know how to convert it over, do I need a new yoke or is there something to convert it to the 6L80?
Is it a bad idea to use that original driveshaft? The car had a 409 in it, torque wise it's about the same as the L99 but had a little less HP.
Thoughts?
Thoughts?
As for setting driveline angle, go to www.hotrodlane.cc, click on the LS installs link and it provides info on how to do it.
http://www.hotrodlane.cc/ONLINETECH/...ineangles.html
