5.3L/4L60E in a 67 C10 issue...PLEASE HELP
I put an 08 5.3L and a 4L60E in my 67 C10 pickup. It runs great except for one annoying issue. Sometimes at a constant light throttle the RPM will raise and lower over and over by about 300 RPM and give a bank 1 and 2 lean code (P0171 and P0174). If I let off or get on the throttle the surging stops and it drives normally. I took a freeze frame of when the issue occurs and got the following:
Fuel sys 1 CL
Fuel sys 2 CL
Calc load 74.5%
ECT 92 deg C
STFT B1 1.6%
LTFT B1 29.7%
STFT B2 1.6%
LTFT B2 29.7%
MAP 78 KPA
RPM 1924
Speed 54 Km/H
IAT 45 deg C
MAF 55.39 g/s
TPS 40%
Run time 443 sec
Command Evap 100%
Warm up DTC clear 9
Dist 115 km
CAT1 420 deg C
CAT2 420 deg C
ECU volts 12.6
Load value 54%
EQ ratio .999
Rel TPS 25.5%
Ambient 28 deg C
TPS B 39.6
ACC pedal D 34.5%
ACC pedal E 17.3%
Command TAC 37.3%
Evap up 1875 Pa
Any help would be greatly appreciated. John from Speartech thinks that it may be that I have an E85 tune on a non-E85 engine. Is this a possible reason for this issue?
Fuel sys 1 CL
Fuel sys 2 CL
Calc load 74.5%
ECT 92 deg C
STFT B1 1.6%
LTFT B1 29.7%
STFT B2 1.6%
LTFT B2 29.7%
MAP 78 KPA
RPM 1924
Speed 54 Km/H
IAT 45 deg C
MAF 55.39 g/s
TPS 40%
Run time 443 sec
Command Evap 100%
Warm up DTC clear 9
Dist 115 km
CAT1 420 deg C
CAT2 420 deg C
ECU volts 12.6
Load value 54%
EQ ratio .999
Rel TPS 25.5%
Ambient 28 deg C
TPS B 39.6
ACC pedal D 34.5%
ACC pedal E 17.3%
Command TAC 37.3%
Evap up 1875 Pa
Or you could have low fuel pressure.
Or the mass airflow sensor could be incorrect for application (as far as how ecm is programmed)
Thanks so much for your help. I guess I will send my ECM back to Speartech and have him change it. This just seemed like such an odd way to "feel" this issue, since it drives perfectly other than this issue.
12580681 non flex fuel 07-08
12594512 flex fuel 5.3L
busta, thanks so so much for posting. I have the non-flex part number, so I will definitely be sending my ECM back in to be reprogrammed. I will also give John at Speartech these part numbers, since he said that he was unaware of a way to tell which motor I have. Maybe this could help someone else in the future.
