where to get MAF sensor?
Old Apr 23, 2011 | 08:49 PM
crosstraining's Avatar
Default where to get MAF sensor?
Where can I get a MAF sensor? I have an ls6 intake on a LQ9. I do not know much about MAF sensor's. Is there a diference b/t a ls1 & ls6 MAF?
Thanks,
Brandon
Old Apr 23, 2011 | 09:02 PM
Pocket's Avatar
Two main flavors of MAFs for conversions. Ignoring the uncommon card styles for newer engines
Stock LS1 3 wires are 75mm, super common on LT1/LS1/vortec trucks, lots of newer FWD cars etc
LSx trucks are 5 wire 85mm, never corvettes, newer northstars etc
For a stock/mild swap a super common 3 wire MAF is plenty
Old Apr 23, 2011 | 09:08 PM
biggeazy-e's Avatar
i have an 01 LS1 & 96 LT1 3 wire MAF f/s if interested
Old Apr 24, 2011 | 12:25 AM
Kooljames20's Avatar
id buy the 01 maf if the op doesnt want it
Old Apr 24, 2011 | 01:39 AM
deuce4935's Avatar
Thanks,
Brandon
If using a truck harness then you will need the truck maf because it has the iat integrated in the maf connector.
Old Apr 24, 2011 | 08:02 AM
Old Geezer's Avatar
Thumbs up Yep!
Old Apr 24, 2011 | 08:30 AM
BelAir1000's Avatar
Obviously, noone's answered your real question. But I agree, stick with the 5-wire maf your harness is wired for.
You can check the local yard. Try using www.car-part.com.
My swap included a MAF. I just ended up buying my accel pedal
via gmpartsdirect.com cause I got tired of talking to the great customer service at the local yards. I had also searched everywhere online.
A MAF should be easier to come buy.
Good luck.
Old Apr 24, 2011 | 08:53 AM
Goldhawg's Avatar
I need to figure out the same thing; my 2010 truck 6.0 MAF was hopelessly crushed in the wreck. I can tell you Rockauto is the cheapest (or one of the online GM places @ ~$60 for mine). I am still just trying to figure out if I can get a shorter MAF that would work for me to give me more flexible mounting arrangements. If anybody knows of another option than stock plz post it.
Old Apr 24, 2011 | 08:54 AM
garys 68's Avatar
Get the MAF for your harness and ecu. They're not very expensive (not wort a trip to the junkyard for me), try Autozone, or Rock Auto.
Old Apr 24, 2011 | 01:22 PM
gofastwclass's Avatar
Originally Posted by garys 68
Get the MAF for your harness and ecu. They're not very expensive (not worth a trip to the junkyard for me), try Autozone, or Rock Auto.
I agree - I also want reliability and getting one from the 'yard isn't the best way to acquire fragile electronics in good running order. For the extra cash of new I would rather not chase potential problems of used on a part like that.
Old Apr 24, 2011 | 02:46 PM
Isolde's Avatar
Interesting thread. I got my '01 LM7 from LKQ, and it did not include a MAF. I'm nowhere near having my swap running yet, but for now I've just been using a '96 Astro L35 MAF for mockup and layout purposes. I was planning to just order a SUM-29006B-C when the time comes.
Old Apr 24, 2011 | 02:52 PM
robbyredneck's Avatar
i have a truck one, if interested pm.
Old Apr 24, 2011 | 03:07 PM
It is a PSI harness. car (ls6 Intake with truck throttle body) & truck injectors. I think I will need the car MAF. I have seen some on here for sale. Will one for an ls1 fit on a ls6? I went to Auto Zone, but they wanted a $50 core charge.
Old Apr 24, 2011 | 03:13 PM
Thanks Pocket,
Will the LS 1 3 wires fit on a truck trottle body?
Does not sound like it. I am 30 minutes away from my car, & did not measure. I assume it is 85mm, but I will measure to be sure.
Old Apr 24, 2011 | 06:25 PM
Thanks Pocket,
I had my Dad check. It is a 5 wire plug & the throttle body opening is nearly 4".
So, I guess I need the 5 wires 85mm truck MAF.
Old Apr 24, 2011 | 10:10 PM
Where did you find 1 for $60? I checked rockauto, autozone, advance, napa, & some others. The cheapest i have found is $120. I do not have a core to trade in.
Old Apr 25, 2011 | 04:19 AM
Goldhawg's Avatar
From rockauto; again for a 2010; don't know whether yours is different:
2010 CHEVROLET SILVERADO 2500 HD LT 6.0L 364cid V8 FLEX FI (G) [L96] OHV : Emission : Mass Air Flow Sensor Wiki Price
ACDELCO Part # 2134343 {#10393948}
SENSOR,MASS AIRFLOW(W/INT AIR TEMP SEN) w/HI CAPACITY AIR CLEANER(K47)
SENSOR,MASS AIRFLOW(W/INT AIR TEMP SEN) w/o HI CAPACITY AIR CLEANER(K47)
$58.79
Add to Cart
Old May 10, 2011 | 06:36 PM
rfrankb4's Avatar
$58.79
Add to Cart
Just FYI this part is a sensor that bolts into the appropriate tubing. It does not include the tube or any associated parts. Like this one but shaped differently
http://cgi.ebay.com/ebaymotors/New-O...Q5fAccessories
