A body clutch pedal help
Tip: Used a vise grip to hold the tab in place and just adjusted it to get the correct 1" travel before welding. There is also post in the FAQ thread on the pedal setup (I think it is from a S&P web site).
I also welded a tab for a travel stop
BC
I am thinking the pedal feels a bit strange without the springs in a factory setup that make the pedal feel linear... how is it to drive?
Also, what does your travel stop have on the end of it? rubber cap or something?
living in OC is great.. can drive right over to Seal Beach and get anything for the Chevelle!
The travel stop is just a Hood stop/adjuster with the rubber cap on it.. seem to workout well... !
I used the oem F-Body clutch Master for a 4th Gen. Used the ATS/S&P adapter plate that I made from the template in the FAQ, was not hard, I used 1/4", but if did again, I'd use 5/16".
It has been working well since late 05'. no problem at all.
Tip: to bleed the Slave, I drilled a hold in the trans tunnel that lined up with the slave bleed valve. Then from the inside, I just use a 1/4" ratch/socket/extention and with a pan under. I step on the pedal and bleed the slave. With the Socket cover the valve. the break fuild will not go anywhere and just drip into the pan below.. Worked out well. The just put a rubber plug in the hole and pull the carpet back (or cut/drill a hold in the carpet).
https://ls1tech.com/forums/conversio...ro-basics.html
I am sure theres an easy way, I believe kst8engineer used the F body brake MC and booster so it might have been easier for him to just start from scratch. I might revisit the idea later if I don't like the travel and feel.
Regarding thickness of the clutch MC bracket, I used 1/8 steel plate, and welded a spacer that bolts the plate to the firewall below the MC to keep the plate from flexing. It seems to do the trick. The pic show the square tube spacer (kinda botched the weld a bit haha)
http://www.summitracing.com/parts/WIL-340-1290/
Wilwood makes various assemblies with different mounting positions.
I went with the wilwood 5/8" MC.
Would anyone who has or can make the bracket want to make another one (I'd pay of course)? I might be getting a t-56 on Thursday so need to start planning.
Doesn't require mods they claim.
They repop and design alot of their own parts and sell them to other parts vendors.
