LSX/T56 RX-7 question.
Old May 21, 2011 | 12:33 PM
03whipedsnake's Avatar
Default LSX/T56 RX-7 question.
I have an FC RX-7 swapped with a 5.3 and T-56, Im having issues with clutch engagement (clutch doesn't engage and disengage properly, hangs before putting in gear horrible pedal feel and so on...) Ive replaced my clutch master cylinder with a willwood 7/8 unit which is modified by hinson for proper pushrod length and ive replaced my slave cylinder with a new unit. Ive also cross checked all my linkage with other swapped rx7's. there is very minimal play in actual pedal but it feels as if the slave is not applying pressure until very low in the pedal throw and adjusting the pedal does not help issue. my only other thought to check is if the previous owner put the wrong clutch set-up in the car as i bought the car not finished but it was already installed in the car. what do you guys think any help would be awesome. Thanks!
