gto ls2 and t56 wont stay running
I have a 2005 GTO 6.0 with a t56 car starts but will only run for 5 seconds vats is disabled
cked the ground on drivers side rear head as well as passenger side front head all is good
Here is what hp tuners is giving me I would aprreciate any help
ECM] P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency (Pending) (Old) (Current) (Immature)
[ECM] P0654 - Engine RPM Output Circuit Malfunction (Pending) (Old) (History) (Current) (Immature)
[ECM] P0685 - ECM/PCM Power Relay Control Circuit Open (Pending) (Old) (Current) (Immature)
[ECM] P1629 - Theft Deterrent System - Cranking Signal (Pending) (History) (Current) (Immature)
[ECM] P1682 - Driver 5 Line 2 (SES) (Pending) (History) (Current) (Immature)
[ECM] P2122 - Throttle/Pedal Position Sensor/Switch D Circuit Low Input (SES) (Pending) (History) (Current) (Immature)
[ECM] P2123 - Throttle/Pedal Position Sensor/Switch D Circuit High Input (SES) (Pending) (History) (Current) (Immature)
[ECM] P2128 - Throttle/Pedal Position Sensor/Switch E Circuit High Input (SES) (Pending) (History) (Current) (Immature)
