Another 1st Gen/LS T56 Swap.
Painted and put my front subframe together, stll need to get swaybar and coilovers for the front. Smoothed drivers side firewall, need to put hole in for steering column. Still have more boxing in to finish smoothing it. Also, started to flush the front windshield. It is good to have a few days off for a change.
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_1edca30e.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_3f5607d7.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_e94c2bbe.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_4d3f3381.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_a56ecf2a.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_0552dbbe.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_a25044df.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_9cce3e66.jpg)
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_46bf47d5.jpg)
It has been awhile since I last posted. I was finally able to wire my PCM and put my fireup tune into it. Last week, I finally decided to try it. It fired right up and idled decently, I was pretty floored. Here is the first fire up. Present was my son, daughter, my Japanese exchange student, and wife. I didn't let it run long at all, because I didn't have cooling hooked up. I have since let it run to temp.
![](http://i296.photobucket.com/albums/mm178/MaroSS_68_Sam/th_DSCN2117_zpsf76d865f.jpg)
