Engine Dies when Shifted into Gear
the IAC would control that portion.
the trans or converter....i dont remember this theres a torque converter clutch? i think thats what its called....maybe someone can help me out, but when shifted into drive, it has to release or lock for the car to idle in drive.....
The torque converter clutch should only lock up when cruising on the highway.
You could try raising the RPM's slightly (with your other foot on the brake too!) when you shift into gear. If the RPM's go down when you shift into gear, but you are able to keep the engine running with throttle....I would bet it's an issue with the IAC.
Maybe you could try disconnecting the driveshaft (as to not put so much of a load on the engine) and see if still does it.
I am using the stock harness and factory fuse box. It doesn't bang into gear or anything. It doesn't try to spit and sputter and run, It is as if the key were just turned off and all power to the motor has been shut off. As for being a bad converter, I dont think it is because it came out of a running driving wrecked truck. The engine and trans were together when I got it in a crate so its never been apart as far as I know so it shouldn't be the coverter but anything is possible. I am pretty sure its a wiring issue and the guy with hptuners will be back tomorrow so I will be able to see if it is throwing any codes.
