Wrecked my RX-7. Won't be fixing it again..... It's over
That does suck. I dont know why anyone would call you out for not wanting to fix it even with all the work involved. At least now you know what it took to get to that point and to add repair to that would be another headache in itself. Nice to see you are still here with us!
At least you are keeping a positive outlook on it and not kicking your own *** for anything. i've forgotten to latch hood pins on my drag car twice and when it was stock the hood blew open on it's own. So that's (3) windshields and hoods and once it hit so hard, the hood slammed the roof down onto the roll bar.
It's a pretty ferocious car, your next one will be better. My second car has only 470 rwhp but it's a true street car. I'm getting older though...
Sorry to hear about the wreck, did the car go straight before with the current suspension setup? I know in my rx7 I had to be careful getting on it the first time we changed something in the suspension, being a 4 link bar, a turn one way or another on the bars and it'd go left or right HARD when it spun.
@ ahhwataday : Really don't see fixing it as an option as I stated before. If you'd like to buy it and try to fix it you are more than welcome to, but as for me: I'm not doing anything more than stopping it down to sell it for parts.
The car would track straight as long as it wasn't spinning. The alignment was good enough to take hands off stewing wheel and it was fine. As soon as it spun the tires hard the rear came around. A differential would have prevented this I think. The spool made it steer because one tire has more traction.
If the frame is straight from the firewall back, someone could easily buy the car and tube the front of it. How much are you wanting for it minus motor? Whats the details on the glide?
Mine is the same way, it can drive straight, but with preload in it, as soon as you get on it and it spins it'll turn quickly on you. I was asking if it drove straight before you did the ls swap with all the current suspension, of if you changed something in the suspension before you did the ls swap. Sounds like something in the rear suspension isn't right, the front end alignment shouldn't affect it like it did.
The glide and converter, I'm gonna keep that stuff for now. $1100 Greg Slack converter. In this car ~ 2400# it sat right at 4400 under load. It's a 1.76, new 8 clutch high gear hub, daaco pump, TCI V. Body with brake, deep pan. I think I'm gonna have to replace the tail housing (bent mount bolt, driveshaft didn't come out easy like before), broke a small piece off the bellhousing that will need to be welded back.
