time for a new project: 1978 malibu LS swap
another update:
got alot done this week - removed the interior to prepare for the chassis shop, removed alot of old (and very scary) wiring, i need to re-do alot of the electrical stuff but i'll worry about it when it comes back from getting the cage.
for the cooling system i used a lower hose from a 78 malibu 6cylinder car and it fit perfectly after i trimmed about an inch off each end. for the upper hose i used an upper hose from 2002 LS1 camaro.
today i came home my buddy who owns the car stopped by with the carb and we bolted it on, hooked up the MSD(temporarily till i make a bracket and mount it inside the car), filled it up with fluids and it fired right up and ran like a top. aside from the fuel pump leaking everything else worked out great.
here's a few pics and a video of it just idling:
![Name: IMG_20110709_164147.jpg
Size: 154.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/672790d1501791986-time-new-project-1978-malibu-ls-swap-img_20110709_164147.jpg)
![Name: IMG_20110709_164135.jpg
Size: 153.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/672791d1501791986-time-new-project-1978-malibu-ls-swap-img_20110709_164135.jpg)
![](http://i154.photobucket.com/albums/s260/lt4malibu/Videos/th_VID_20110709_155035.jpg)
oh and we did a rough estimate of how much it cost to swap do this swap and so far i think he's at $2600 for me to get it running. here's a quick breakdown:
-2002 LS1 $1400
-parts sold that werent needed: harness, ecm, intake, accessory drive, MAF, etc -$1040
-electric water pump $480
-hughes flexplate $140
-BMR alternator bracket $120
-transdapt motor mounts $75
-Fbody pacesetter longtubes $280
-intake $600
-6LS MSD $300
-carb rebuild $125
-misc hardware, fittings, hoses, belt, fluids $120
keep in mind we had alot of major components such as the trans, converter, and carb(just needed a rebuild).
-2002 LS1 $1400
-intake $600
-6LS MSD $300
-carb rebuild $125
#32
No updates really, still waiting for the car to come back from the chassis shop so I can re-wire it. I did pickup another g-body I'm gonna use for a daily driver ill be sure to keep yall updated.
just went through my phone, found a few pics :
![Name: PART_1316972596901.jpg
Size: 69.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/672792d1501791986-time-new-project-1978-malibu-ls-swap-part_1316972596901.jpg)
![Name: PART_1316972518487.jpg
Size: 88.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/672793d1501791986-time-new-project-1978-malibu-ls-swap-part_1316972518487.jpg)
![Name: PART_1316972330973.jpg
Size: 36.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/672794d1501791986-time-new-project-1978-malibu-ls-swap-part_1316972330973.jpg)
![Name: PART_1316972330821.jpg
Size: 23.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/672795d1501791986-time-new-project-1978-malibu-ls-swap-part_1316972330821.jpg)
#34
What are the part numbers for the upper and lower hoses? I see that they arefrom gates.
And great build by the way. Oh have you started on the other gbody yet and will it have powersteering?
#35
dont know about the part numbers, the upper is for a 98-2002 F-body, the lower is for a 78 malibu with a V6 (i trimmed it a little) these may not work with a stock type pump.
as for MY car, im not sure if im gonna keep the power steering just yet. hope to start working on that in the next week or 2
#39
can u give the part numbers to all which u used far as the motor mounts converter spacer and flex plate u r using i see u did move ur trans and didn't have to shorten ur drive shaft so if u can please let me know that what u did saved a lot of money thanks
