Th350 VSS question
Old Jun 12, 2011 | 02:41 AM
Dillon79scotts's Avatar
Default Th350 VSS question
I havent really heard or seen Anyone say much about there stock vss,
My question is, i am running a 5.3l, getting computer flashed to delete a bunch of stucx, but i saw on lt1swap.com that he is saying you need a electric vss pulse to the pcm,
Is this true? Says it can effect fuel mileage, idle issues. Has anyone done this before and is it a must?
Old Jun 12, 2011 | 02:43 AM
*stuff* not stucx
Old Jun 12, 2011 | 11:48 AM
the_merv's Avatar
Veteran: Air Force
Depends on how you have the tune..if you set it up for a standard then it might not matter in a way. There are conversion kits out there.
I'm about to put a TH350 into my car and I have an extra T56 Reluctor layin around, I'm looking into modifying it to work on the Tailhousing with a VSS.
Old Jun 12, 2011 | 11:56 AM
deuce4935's Avatar
NOOOOOOOOOOOOO!!!!!!!! Why Merv why? Tell me you didnt hurt the T56 again. To the op, most guys run a vss to keep the engine from stalling when you come to a stop and to help the idle. Dakota Digital has a setup thats been used countless of times as well as JagsThatRun.com
Old Jun 12, 2011 | 01:33 PM
the_merv's Avatar
Veteran: Air Force
Lol..that's the Track Trans, the T56 will still be in it for the street fun..
Old Jun 12, 2011 | 06:05 PM
Slow 346's Avatar
I have a Turbo 350 in my Nova swap and im not running a VSS. The car starts, idles and runs fine. Even when coming to a stop.....no issues at all.
Old Jun 12, 2011 | 06:50 PM
jmd's Avatar
jmd
get the 40 tooth wheel, sensor and tailhousing from an early to mid 90s 2WD truck that has it.
those 4L60 model tailhousings bolt to a 6" tail Th350 or bolt to a 9" tail w/ a spacer.
Old Jun 12, 2011 | 08:35 PM
w4625's Avatar
Does the same apply to the 700r4?
Old Jun 12, 2011 | 10:16 PM
deuce4935's Avatar
Depending on the year, some of the 700r4's had tailhousings with vss.
Old Jun 12, 2011 | 11:06 PM
the_merv's Avatar
Veteran: Air Force
That thought crossed my mind, where did you get the spacer?
Old Jun 14, 2011 | 02:11 AM
welldonecj7's Avatar
what about if you have a 4wd trans? Just one of the dakota digital ones?
Old Jun 14, 2011 | 06:26 PM
Monza355's Avatar
I put a th350 in my Monza with the LS1 with no VSS and never had any problems.
Old Jun 14, 2011 | 07:09 PM
1FSTLS1's Avatar
I have th400 and motor wants to die comming to a stop. Idles and drives fine. I am hooking mine up tomorrow.
Old Jun 14, 2011 | 07:53 PM
jmd's Avatar
jmd
Post
https://ls1tech.com/forums/automatic...wap-4l60e.html
get the 40 tooth wheel, sensor and adapter or t-case? from an early to mid 90s 4WD truck that has it.
Old Jun 14, 2011 | 08:51 PM
the_merv's Avatar
Veteran: Air Force
Bad ***..
