5.3/4l60e in 99 jeep tj problems. Need HELP
I got the 5.3/4l60e out of a 03 2wd escalade. I am using the novak adapter (with their vss sensor) joined to my original 99 jeep tj tcase. I have wired the project myself. Installed a cam, 3k stall, and had someone turn off the vats and rear o2s, and do a base tune until it is drivable for a final tune. Jeep runs great in all aspects except for when it shifts into second gear its slips very badly every time. It only slips in second gear. The trans was originally gone through when the output shaft was changed to accept the adapter. Since then I have pulled it back out, brought it to another good builder and found nothing wrong with it. The trans shift very well, its just after the shift it will not hold second gear. If I manually put it down into second gear it will not slip at all. Im leaning towards a electrical problem after talking to a few people, any ideas?
