Hooking up DBW?
Old Jun 18, 2011 | 01:55 PM
retardedpenguin's Avatar
Default Hooking up DBW?
Can anyone help me? There's like 5 wires on the pedal but 9 going to the plug, are the others not used? It was cut when I got it so basically I have the pedal, plug and wires and the module, plug and wires but there are more wires on the module than the pedal...
Old Jun 18, 2011 | 04:03 PM
ls1nova71's Avatar
The other wires are for cruise control, there should be a gray, gray with black stripe, and a dark blue that go to the cruise switch. If you're not running cruise, you can get rid of them.
Old Jun 19, 2011 | 12:04 AM
busta9876's Avatar
what year you working with here? 2003 to 2005 had a 10 position plug on each end, one end white, one end black. Some years had 9 wires, some only had 6 wires. From my understanding, from 2003+ only 6 wires were needed. In 2006, the gas pedal went to a smaller plug, but other end at the TAC module was still the same.
first attachment named "Engine Data Sensors - Electronic Throttle Controls.gif" is the 2006 schematic. Notice the pin location for the APP sensor (gas pedal) is 1,2,3,4,5,6. This is the small 6 pin.
The second attachment is specific to 2004 truck. Its labeled with letters. The schematic shows APP Sensors 1-3, however, I have seen these with just 2 of the 3 wired up. I can't remember exactly which one is not used.
pull the gas pedal to tac module jumper harness out of your 04 caddy and look at it.
Attached Thumbnails Hooking up DBW?-engine-data-sensors-electronic-throttle-control.gif   Hooking up DBW?-electronic-throttle-controls-2-2.gif
Old Jun 19, 2011 | 01:22 AM
I have no clue what years, they just gave it to me out of a silverado(junkyard). There are 9 wires on the module and 6 on the pedal.. Unfortunately I don't have the caddy any more. I just matched the colors up and yeah, didn't work lol..
Old Jun 19, 2011 | 04:50 PM
So which wires go where?
Old Jun 20, 2011 | 07:47 AM
Jim_PA's Avatar
None of the cruise control wires go between the TAC and the pedal.
It looks like you have a 2003'ish TAC module (3 APP sensors) and a 2005'ish pedal (2 APP sensors).
You need a different pedal or a different TAC module, but the OS (year, mainly) inside your PCM would dictate which part you need to change out.
There's some good 2003-2004 (3 APP sensor) schematics here on pages 1 and 3: https://ls1tech.com/forums/pcm-diagn...al-travel.html
Old Jun 20, 2011 | 08:30 AM
FastKat's Avatar
This is correct - none of the wires between the TAC module and the pedal go to the cruise control.
I'm not so sure about this, though I could be just lucky. I am successfully running a 1997-04 Corvette DBW system (TAC module, throttle body, pedal) on a 2006 Sierra 2500HD PCM and harness. I think the important thing is to make sure the TAC module, throttle body, and pedal are all compatible. If that's the case, you can use them (together) on a wide range of LS-based vehicles. Of course, the PCM should be from a DBW vehicle that uses a TAC module. (Some PCMs are not DBW, and some of the later DBW systems do not use TAC modules.)
PM me if you need any wiring diagrams.
Old Jun 20, 2011 | 08:39 AM
Jim_PA's Avatar
I'm not so sure either, but I know something is different between 2004 and 2006 OS's for the pedal (at the very least).
To avoid buying any other mismatched stuff, I'd recommend going by the year/make/model of the OS when getting a TAC/pedal.
Old Jun 20, 2011 | 10:36 AM
ls1nova71's Avatar
Before he posted the pics, I thought he was refering to his engine harness was cut before the TAC, the other plug.
Old Jun 20, 2011 | 11:14 AM
Alright, guess imma run by the yard and get a 2 sensor tac. My engine is an 04 and I think the PCM is also.
Old Jun 20, 2011 | 11:47 AM
Jim_PA's Avatar
The wires you are holding up from the TAC tell me you have the 3-sensor TAC, but I'm not so sure if using the 2 sensor TAC/Pedal with a PCM configured for 3 sensors will work or not.
A - Gray
B - Purple
C - Lt Blue
D - Tan
E - Yellow/Black
F - Blue
G - White/Black
J - Brown
K - Green
At the pedal, they need to be mapped like this:
TAC - PEDAL
A-A
K-K
E-J
B-B
C-C
D-D
J-E
F-F
G-G
You could try to pin the TAC-Pedal cable like above, it might work just fine. I'm not sure if they actually use a different pedal sensor, or if they just don't hook up the 3rd APP circuit in the later years.
https://ls1tech.com/forums/14466569-post44.html
Old Jun 20, 2011 | 01:06 PM
My pedal is missing the J wire.
Old Jun 20, 2011 | 01:32 PM
Jim_PA's Avatar
Well, I guess we know they use different sensors
Old Jul 9, 2011 | 12:17 PM
So I got a different Tac with 6 wires but the plug is smaller than the one on the pedal, I tried to match everything up and it still doesn't work.. What now?
Old Jul 9, 2011 | 03:09 PM
I've gone through 3 different pedal/ tac set ups in every combo possible and nothing works. I don't know what to do right now, what's the deal? Can the TB go bad?
Old Jul 10, 2011 | 02:42 PM
Anyone?
Old Jul 10, 2011 | 08:57 PM
FastKat's Avatar
What kind of vehicle did your throttle body come off of? Some sort of Cadillac?
Old Jul 11, 2011 | 10:16 AM
04 silverado. I've tried every tac/ pedal set up from 03 to 06.
Old Jul 11, 2011 | 11:43 AM
psiconversion's Avatar
LS1Tech Sponsor
What tune is on the pcm?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jul 11, 2011 | 02:53 PM
I don't know, I'm going to take it to g force tomorrow, had to help a friend out today so I didn't have time.
