ls1 not oiling
Old Jun 18, 2011 | 03:01 PM
Tony C.'s Avatar
Default ls1 not oiling
Ok where should I start, I installed an ls1 in my caprice let it run about 5 minutes then it started to tap. I removed the valve covers and notice there is no oil coming out the pushrods on either side, I have around 33psi. Do I need pump or check pickup oring
Old Jun 18, 2011 | 06:32 PM
Jimbo1367's Avatar
Check the pick up o-ring. WHat have you donw to the motor since this happened?
Old Jun 18, 2011 | 07:06 PM
71ANTICARB's Avatar
So you have 33psi on the gauge and no pik at the top of the engine?
Old Jun 18, 2011 | 07:28 PM
LS1_911's Avatar
o-ring
Old Jun 19, 2011 | 10:29 AM
Tony C.'s Avatar
Yes my Gage is showing 33psi but there is no oil coming out the push rods. I'm gonna pull the accessories and change the pump and o-ring.
Old Jun 19, 2011 | 10:33 AM
Jimbo1367's Avatar
I wouldn't change the pump just yet. My guess is the oil ring is pinched. Very common.
Old Jun 19, 2011 | 12:00 PM
71ANTICARB's Avatar
I'm not argueing with anyone, but if he is showing oil pressure on the gauge wouldn't that mean that it is picking up oil?
Old Jun 19, 2011 | 12:56 PM
Jimbo1367's Avatar
True, but maybe not enough pressure to fully pressurize the entire system.. I don't know. But I would personally recheck the o-ring for a piece of mind. I am curious to see if this engine has had anything done to it since it was removed. Was this engine running and he upgraded parts and no oil to the rockers?
Old Jun 19, 2011 | 01:08 PM
Tony C.'s Avatar
Well i got the engine used from a guy that said it had 60,000 miles on it. What I did notice was the heads looked new inside and out. He didn't mention doing any work to it but someone did.
Old Jun 19, 2011 | 01:16 PM
Tony C.'s Avatar
When I first cranked the engine it ran great till the lifters started making noise. I shut it off pulled the covers and started it again and notice no oil coming from the push rods
Old Jun 19, 2011 | 03:27 PM
lizeec's Avatar
It doesnt make sense if it is showing 33 psi that is plenty of oil pressure at an idle even when the engine is cold. If you visually did not see any oil up top as you stated, are you sure your gauge is a known good gauge and is accurate.
Old Jun 19, 2011 | 05:10 PM
Tony C.'s Avatar
Ok guys this is what I have so far. I removed the accessories and the bolt for the tube to the pump I removed with my hand it wasn't tight. I picked up a gasket set from the part store it had a green and a red o-ring and the one in the pump is blue and much smaller. This might be my problem.
Old Jun 20, 2011 | 12:33 PM
Tony C.'s Avatar
I'm going with the red one, the green o-ring seems to be a little to big
Old Jun 20, 2011 | 03:57 PM
Jimbo1367's Avatar
Good luck. Let us know if you get it fixed. Hopefully this does it, and you didn't do any damage.
Jim
Old Jun 20, 2011 | 05:34 PM
71ANTICARB's Avatar
Think maybe it wasn't fully primed?
Old Jun 20, 2011 | 09:34 PM
Tony C.'s Avatar
I wanna say thanks to jimbo1367 and guys for the help. Problem solved I'm at 42psi and oiling Just hope I didn't hurt anything.
Old Jun 20, 2011 | 09:36 PM
71ANTICARB's Avatar
Just replaced the "O" ring?
Old Jun 20, 2011 | 10:25 PM
Tony C.'s Avatar
Yes I replaced the o-ring and that did it.
