77 280z ls1 wiring
Old Jun 18, 2011 | 05:27 PM
perzn's Avatar
Exclamation 77 280z ls1 wiring
hi guys, i need some help with wiring the ecu. I have searched everywhere, but everything was related to stock harnesses. I am using a 98 corvette motor and a 2000 t-56 from a camaro. an aftermarket harness and ecu made and tuned by psi conversions. the harness has 8 wires and i dont know where to connect them, not sure if i am suppose to connect or t splice the wires into datsun dash harness or what. I am using the ls1 kit from Johns cars. i am using mechanical speed sensor to keep my original speedometer and gauges.
just need to connect these last wires and the car will be pretty much ready for start up. all help is appreciated.
wires are:
(brown)- ignition feed(from relay center)
(black)-speedometer(optional)
(green)-fan 1(optional)
(brown)-MIL ground
(purple)-brake signal/tcc ground
(orange)-park neutral
(white)-tachometer(optional)
(blue)-fan 2(optional)
Old Jun 18, 2011 | 09:31 PM
perzn's Avatar
Bump 10char
Old Jun 21, 2011 | 10:06 PM
240dan's Avatar
wires are:
(brown)-MIL ground
More info might be needed but I'll try to help a fellow z-car guy out here.
(brown)- ignition feed(from relay center) - ignition hot
(black)-speedometer(optional) - may or may not be used, many speedos use the vss signal not the speedo output. If you use the stock speedo, a mechanical converter will be needed.
(green)-fan 1(optional) - connect to relay to activate fan, should activate relay ground.
(brown)-MIL ground - ground for your check engine light.
(purple)-brake signal/tcc ground - most likely unused in your case (T56)
(orange)-park neutral - most likely unused in your case (T56)
(white)-tachometer(optional) - tach output signal
(blue)-fan 2(optional) - connect to relay to activate fan 2 (if used).
If your harness did not come with one, consider getting an additional fuse box (like the painless) to power the constant and ignition hots. Makes life easier. Good luck
Old Jun 22, 2011 | 06:31 AM
psiconversion's Avatar
LS1Tech Sponsor
240Dan, thanks for the tech support. Want a job??
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jun 22, 2011 | 03:48 PM
240dan's Avatar
You got a job mang!
No prob, happy to help when I can.
Old Aug 19, 2011 | 10:13 PM
perzn's Avatar
Originally Posted by 240dan
You got a job mang!
Thanks for the help. all wires are hooked up. I tried to start it up but their was no crank just silence but the fuel pump worked fine. Not sure if I did something wrong. I'm pretty sure everything is right but not sure about ignition feed wire, don't know what u mean by hot wire. You mean like constant, like recieving 12 volts even in off position?
Old Aug 20, 2011 | 11:14 PM
perzn's Avatar
nvm, figured out the problem. my car use to be an auto so the 2 black/yellowstripe wires that were connected to the relay next to the fusible links had to be cut and connected together. same color wire that connects to the prong on the starter. now it cranks but gas isnt coming out of the injectors, so its all starightforward from here.
Old Aug 23, 2011 | 10:06 PM
perzn's Avatar
damn it. new problem. i made progress and it runs....but... only in the "start" position. if i let off of the key the engine dies. can that be related to not having constant spark, or the fuel pump not staying running on the "on" position? all help is appreciated.
Old Aug 23, 2011 | 10:11 PM
popethe5th's Avatar
check either at the relay or pump its self to see if the Fuel pump isnt getting power in the on position, also beware of alldata's wiring diagrams, i know when compared to the GM one I was missing a power wire on my pin out chart.
Old Aug 23, 2011 | 11:49 PM
perzn's Avatar
oh i havent used any gm diagrams. just the datsun one. yea ill check out those few things in the morning. its 11:44pm right now. put a voltmeter at the pumps + terminal and ground to chassis to see if i am receiving power on the "on" position correct? well i would hear the pump whinning if that helps. hmmmmmmmmmm
Old Aug 27, 2011 | 01:18 PM
popethe5th's Avatar
id see whats losing power resulting in the engine to die, is there 12V in the run position at all injectors, coils, and pump? and again check PCM power from ignition switch
Old Aug 27, 2011 | 02:35 PM
perzn's Avatar
i figured out the problem, just had to solder ignition feed wire to an IGN 12v source, for example one of the 2 fuse wires in the back of the datsun fusebox center.
Old Aug 27, 2011 | 03:31 PM
popethe5th's Avatar
gald to hear you fixed it!
Old Aug 27, 2011 | 04:31 PM
perzn's Avatar
thanx. it was obvious but just my mind wasnt thinking straight.
