My tri-five swap has begun, I need suggestions...
I think the DBW would give you a clearer look. By not having the Cable and cam,etc.
But, they both well work.. use what you got, unless you want to go one way or another.
Advantage of a DBC is that if it get stuck at WOT, you might be able to use your foot on the pedal to pull it back.
Also, there is no modules or electronic to fail and leave you out in the middle of nowhere, not that it is going happens a lot. But go figure, it will happen to you (or me), Murphy law..LOL.
Then again. you might break a cable..
