66 Nova LS1/4l60E Swap
Old Jun 25, 2011 | 08:22 PM
waderaces427's Avatar
Default 66 Nova LS1/4l60E Swap
66 Nova SS with a ZZ4 and 700 Bowtie Overdrive
Donor Car 98 Trans Am
LS1 in the Nova. While the engine was out, I changed the oil pump, heads,lifters, camshaft, and intake. Using a 6cylinder Trailblazer converter...
Old Jun 25, 2011 | 08:59 PM
Jimbo1367's Avatar
What is the purpose of the 6 cycl. converter?
Old Jun 25, 2011 | 09:19 PM
Default Converter
Trailblazer converter behind the ls should produce about a 2500 stall speed which matches my camshaft. The converter was recommended by a local ls1 engine builder for a good street converter when matched to a cam with a duration in the 220-224 range.
Here are some pictures of the Champion radiator and the trimmed up Fbody fans.
Old Jun 28, 2011 | 10:06 PM
JohnnyWarfare's Avatar
beautiful car, doesnt seem like it took you long to get that ls1 in there. or did it? good luck with everything
Old Jun 28, 2011 | 10:55 PM
Default Fired it up but...
Well, I sold my old drive train March 10 and that was the beginning of the swap. Thanks for the compliments. I am using DBW and I have the following codes on my 02' 0411 computer with 02 corvette tb,pedal, and tac module. Any help would be appreciated as the car fired and ran for a couple of seconds then stopped.
1220 TPS
1221 TPS sensor correlation
1120 TPS Circuit Performance
1125 App system
1276
Old Jun 29, 2011 | 06:31 AM
psiconversion's Avatar
LS1Tech Sponsor
Does the 02 computer have a Corvette tune on it?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jun 29, 2011 | 11:05 AM
yes....the computer was setup with all the engine and car specs.
Old Jul 12, 2011 | 02:23 AM
dookstainsteveo's Avatar
It's the vats
Old Jul 12, 2011 | 02:24 AM
You need to get the vats taken off. Very interested in what oil pan and mounts u used. I just got done with a 72 nova ls1 swap now I have a 67 post car to do.
Old Jul 13, 2011 | 08:46 PM
Default Problem Solved!!
I was running the engine to check for leaks, errors, etc. I did not have the drive shaft in BUT the VSS was connected. The computer was reading 4-7mph from the VSS and cutting the fuel. Once the VSS was disconnected the engine would rev. Having the driveshaft made so I can get the car on the road.
I am running a stock F body pan and Church Boys adapter plates, stock mounts, and Church Boys SW headers. I have a bunch of pics on SNS in the lsx section...
Old Sep 19, 2013 | 01:03 PM
Bad66's Avatar
Could you tell me the P/N on the oil pan please. Going to do a swap on my 66 Nova and i dont want to make mistakes, any help would be great thank you.
Essen
