LS1 / T56 280Z on the dyno
I was very happy with how the car performed.
Specs:
Stock 2001 LS1 bottom end
62CC AFR 205's
Vengeance VRX4 Cam - 228/230 .588/.592 on a 112 LSA
FAST 90 Intake
Nick Williams 90mm TB
Nitrous Express Plate
Custom 1.75" long tubes, true dual 3" with x pipe, out the back with magnaflow bullets
Built T56
Custom Ford 8.8 IRS swap
Baseline of 431 /412
ended up 442 / 420
on 150 jets it made 576 / 616
Its pretty violent when it hits... almost scary lol.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20130523_241038_182_zpsea8cda10.jpg)
![](https://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_0884_zps47ff99ff.jpg)
![](https://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_0883_zpseda6d6e1.jpg)
All of the motor pulls
![](https://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_0888_zpsc9abc4ff.jpg)
Nitrous pulls - 150 jets (62N / 34F)
Specs:
62CC AFR 205's
FAST 90 Intake
Built T56
ended up 442 / 420
![](https://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_0892_zpsbbd39545.jpg)
Did you notice a huge difference with the extra weight taken off and such? I have a 5.3 block and 799 heads, 228R cam, LS6 intake, and it will have the normal headers and such. Weight savings and the extra cubes worth it?
If you wouldn't mind asking, buying the whole set up for the ls1 kit, harness, headers, heads and intake. How much was it? And would it be a ton cheaper to just get a stock ls1 and some heads and a cam set up instead of a whole set of performance parts. For a kinda small budget build what the best decision?
