LS6 Cobra
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Also, what type of tank does it have in it and is it baffled? The reason I ask is depending on the fuel level in the tank it can uncover the pump. It is interesting that you can replicate the problem and it does it at the same RPM.
I'll ask him about the tank.
I have a feeling he'll be much happier with the genuine article, let us know how it goes.
edit to add: here's an article on the subject with lots of good info on detecting the cheap knockoffs:
http://www.fuel-pumps.net/walbro-forgeries.html
Your second one worked fine though right?
So I should have got the "real" Walbro or Aeromotive from the start and saved me some grief. As UNREAL mentioned I did order the Aeromotive 340 so I am hoping for a resolution.
By the way the Nova that UNREAL mentioned is a 1966 and I will start to work on that when the Cobra is 100% done. More tinkering........
Thanks for all of the assistance and feedback. It is great to be able to post issues and questions on this forum and all of your collective help.
I am planning on installing the pump in the next day or two and will let you know how it works.
so it was easy to R&R the pump. I am surprised at how much better the car drives just cruising around. The wife even noticed it. I ran it up in RPM and can tell that it does not cut out as before. I did not run it hard as I would like to have UNREAL have the laptop hooked up to it so I can monitor the knock or anything that may be non-normal.
I wish I would have bought the good pump from the start and not tried to save the money on Ebay. Lesson learned. The Aeromotive pump was a simple replacement and the quality looks great. Too bad I had to hide in the gas tank.
