no start!
Old Aug 7, 2011 | 05:05 PM
  #61
Joe H's Avatar
Well I got it started, it was sounding good but it died. Now I now longer have the ignition light on when I go to start the carBefore the noid light would go out when I tried to start it, but was on with the ignition switch on! I installed a pushbutton switch under the dash but it only worked once! No sure what I did, cheched fuses and they are good.Now it will start only if I hold the button in.The noid light is off with the ignition switch in the on position now. HELP
Old Aug 7, 2011 | 08:00 PM
  #62
ls1nova71's Avatar
If it works by holding the push button switch on, then it sounds like that switch is fried. What amp/ kind of switch is it?
Old Aug 10, 2011 | 04:52 PM
  #63
Joe H's Avatar
It is a stock ignition switch but I bought it from O'Reillys so it may be a cheap one. I will get one from Autozone and see what happens. thanks for the advice.
Joe
Old Aug 27, 2011 | 04:10 PM
  #64
Joe H's Avatar
I am thinking I may not have the pushbutton wired right. how should this be wired?
Old Sep 25, 2013 | 09:50 AM
  #65
clary1's Avatar
I have recently purchased a 02' SS camaro. Stock except LS6 putons,LS6 oil pump,Timing chain,Lunati Lifter w/4:10 gear (so I'm told) car runs great, I go to get in this morning to move out of garage and no start, curious if anyone else has this prob, I'm sure minor (hope) and does it have a safety neutral switch? Or your thoughts please.
Thanks for any advise. David.
Old Sep 25, 2013 | 09:51 AM
  #66
clary1's Avatar
Pistons+++ sorry
