45 degree flare on spectra tank leaks...
So I hooked up the 45* flare pressure line on my spectra tank to a hose I made with Aeoroquip fitting # FCM-1134. It's a TFT hose end for 45* flare. I filled the tank and pressurized the line and at first it was good until I saw a slight drip from the pressure side from the fitting. It is hard to tell whether I just botched the hose end or whether I have the wrong fitting, but people have confirmed this hose end works on this forum.
I know in an fittings you don't need thread tape, but do you need it on 45* fittings?
I just went through this with my fuel system. I had done as much as possible with hard lines but every hard line connection leaked. And I tightened the bejeebus out of them too. A friend recommended I use conical seals. Got them in Sunday and no more leaks. Here is what I bought:
http://www.summitracing.com/parts/EAR-169106ERL/
Not sure if they will work with your 45 degree flares or if they make them for the 45 degree flares. Are you sure its 45 degrees? Seems kinda odd to me since the most common fittings are all 37 degree.
Best of luck!
Best of luck!
