G body oil pan Q?s
G body oil pan Q?s
Seems like for G body setups, there are three options..
Car is an 81 malibu on coilovers and sits very low in the front.. ground clearance is an issue.
Stock truck pan (hangs ridiculously low)
H3 (Muscle car pan kit) Hang about 1 1/2 inches below k member.. not too bad as thats about how far headers will hang. Is pretty cheap (150 for kit ~)
CTSV pan.. only hangs down about 1/2 inch past k member. Uses 5.3 windage tray, so all I need is pickup and pan.. but those two parts are extremely pricey.. (300$!)
I'm not looking to do a billion dollar setup.. car is just a fun cruiser with a main concern of reliablilty and driveability.
Look into the champ sheetmetal pan. Oil filter is in stock location. I think it was 300 bux total. fits my 87 gn nicely, and also was fitted on a 67 camaro and fit fine.
http://www.champpans.com/index.cfm?e...tdetail&id=193
The mounts and the position will be the other variable..
Per this thread I Used John Bs mounts and CTS-V Pan
https://ls1tech.com/forums/conversio...-v-john-b.html
Here is another thread in which I psoted the website for the CTS-V pan and I also listed the part numbers.
https://ls1tech.com/forums/conversio...l#post14806670
At the time I purchased the Pan and other necessary parts shipped to my door was 144 bucks.
Not certain what it is now as i dont know if anybody inquired on the info I posted.
It all depends on your mounts. The cts-v pan will not work with the BRP mounts in the holes already drilled. Adapter plates with the clamshells may be different. The BRP mounts raise the engine up quite a bit, making the musclecar pan work very well. The BRP longtubes hang lower than the pan.
I was all set to go with the GM Muscle Pan kit and you had to post this!!!
That pan looks VERY nice! Just trying to justify 2X the money!
What oil pan gasket are you guys using with the Champ?
Thanks
Don't look at it as twice the money look at it as done right the first. I am gonna end up spending over $450 on my pan now since I went the lh8 (muscle car pan) route first.
I just put the Moroso TBSS pan on mine. That thing is a work of ART. just dont want to spend that kind of coin on something my Son is going to drive someday.
That Champ pan is a good price. Was just trying to be less over the top on this car... No one will see it anyway.
Mine will be going on a ls2 into a 87 Monte Carlo SS.
Casey does the Champs pan hang low like the guy in your Avartar LOL. Pics would be great, I have truck pan on my 6.0 now and dont want to try and drop my engine in till I see some pics and decide to go from there
thx
Lenny
thx
Lenny
Did you see this one talk bout over the top.
http://www.champpans.com/index.cfm?e...tdetail&id=194
Still not a bad price for what it is.
