3 speed on 5.3 questions
Old Jul 13, 2011 | 06:08 PM
5.3Lnova's Avatar
Default 3 speed on 5.3 questions
I have an 09 5.3 lmg I am outing in a 69 nova and I want to reuse my transmission due to money issues. My problem is I just bought a flywheel for the motor and now my bellhousing doesn't fit over the flywheel. I remove te starter and tried again with no luck. Any suggestions would be helpful.
Thanks
Old Jul 13, 2011 | 08:26 PM
garys 68's Avatar
Info for a 10 spline muncie on an LS, hope it helps.
https://ls1tech.com/forums/conversio...442-build.html
Old Jul 13, 2011 | 09:13 PM
bczee's Avatar
What transmission are you using. 3sp Auto or a 3sp manual ?
A little bit more info would help.. even pictures.
Old Jul 13, 2011 | 09:17 PM
5.3Lnova's Avatar
Thanks for the info the flywheel info will help but my problem is the bellhousing is too small for the fly wheel and I know the flywheel is right because the starter matches up. I don't think it will make a difference but the bellhousing is from a 6 cyl. Thanks
Old Jul 13, 2011 | 10:17 PM
bczee's Avatar
your old 6 cyl is normally a 158t Flywheel and the Gen III/IV is a 168t .. The old 6 cyl bellhousing will not fit over the 168t flywheel.. but I am assuming here. cause you have not stated specific information on what came from where..
Old Jul 14, 2011 | 06:34 AM
garys 68's Avatar
Since you say flywheel and not flexplate, I'm assuming manual trans (3 speed muncie/saginaw with 10 spline input). The 168 tooth LS flywheel will need a 621 BBC bell housing or the Keisler version with the extra LS bolt hole.
Old Jul 14, 2011 | 06:51 AM
LS1MCSS's Avatar
OP, there are at least 15 of the 621 bellhousings on ebay right now.
Old Jul 14, 2011 | 07:46 AM
5.3Lnova's Avatar
thanks for the info guys and yes the trans is a saginaw 3. ill check ebay now. thanks
Old May 25, 2015 | 11:13 AM
JCM1's Avatar
I know this is an old thread but wanted to ask OP how this turned out. Op - are you around? How did the Saginaw 3 speed mate up to the LMG? I'm in the beginning stages of the exact same swap. THANKS!
Old Dec 22, 2023 | 09:05 PM
Jhutch's Avatar
Default Anyone check this anymore?
I know this is way old. But is there any luck or any info that can be given. I am in the middle of this same swap....
Old Dec 23, 2023 | 12:08 AM
Scarebird's Avatar
I put a TKX behind a Gen V 5.3 It does require a different offset bellhousing, as did my TKO/LS3 combo.
Note to check engagement depth with 5.3's as if the crank pilot hole is too shallow you will break you block tightening it down.
https://ls1tech.com/forums/generatio...nsmission.html
Another item to check is test fit the bell housing on the block - my 5.3 had some bolt heads on the cam cover sit too proud and not allow the bell to fully seat.
