1970 Chevelle - LY6/4L80E swap
Good to see you are back in the hunt again. All of the work and frustration will soon payoff. I have done several projects like this and before you know it you turn the corner and it is all coming together. Just never total up your receipts!
Yeah, its been a long process..and I'm scared to add up the receipts. I'm actually to the point where I'm hoping to fire it up in the next week or two. I'll be working on catching up the thread here over the next couple days.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
First test fit of the motor and trans.. using Dirty Dingo plates (not the sliders, just the 3 position adapter plates) with energy suspension poly mounts. Used a G-force trans crossmember with poly mount. It fit well on the first try, surprisingly. And the body work took months....
