Old May 18, 2016, 06:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
LSx engine swap guides
Old Oct 9, 2019 | 01:46 PM
  #81
rabies's Avatar
iv searched and haven't found anything on the Nissan hardbody. I have a 97 called a pickup now.
I can make mounts. wiring use standalone? how does that work. I want to keep things simple. using T56
Old Oct 9, 2019 | 06:23 PM
  #82
john morse's Avatar
Stand alone harness. This does not involve butchering/tie into original car harness. It is for engine only and adapts to any car but is specific to particular engine and its corresponding computer (ecm). It comes with a relay package and a fuse package. Relays are typically for ignition and fuel pump. Fuses in fuse block protect devices that the harness serves such as injectors, O2 sensors, etc. As a rule you put the relay/fuse block assembly inside of the car along with the ECM connectors which will be part of the standalone harness. Thus the ecm connectors, relays and fuses are typically inside of the vehicle and the remainder of the harness has dedicated places to go on the engine such as alternator, injectors, sensors, cooling fan relays, etc. Typically a always hot and or a switched hot is required to attach to the relays on your end.
It is customary for harness providers to ask you questions related to what type of alternator connector, drive by wire or cable driven throttle body, etc. They, in turn custom fabricate every harness to your particular engine and ecm. Hope that helps. Prices are generally 5 to 6 hundred dollars.
Old Oct 10, 2019 | 09:04 AM
  #83
rabies's Avatar
awesome thank you sir. clears up a lot. this is my route. easier and simpler(less for me to ruin)
Old Apr 27, 2021 | 08:38 PM
  #84
jerry moses's Avatar
i am doing and LS3 swap and i need an accelerator pedal for DBW and i cannot find one, i would appreciate any help please.
Old Apr 27, 2021 | 11:33 PM
  #85
Which DBW TB are you using? As in out of which vehicle? Get a DBW pedal out of one of those vehicles.
Old May 3, 2021 | 01:32 AM
  #86
i keep on getting the wrong one, i need to know the model number of the pedal
Old May 3, 2021 | 09:39 AM
  #87
You still didn't answer my question....
