accessory belt question
Old Jul 29, 2011 | 07:06 PM
shrike's Avatar
Default accessory belt question
Hi,
I have a 1999 4.8 truck engine with a mechanical fan. For my application I would have to ditch it and put electrical fans because of clearance issues.
In order to remove the mechanical fan, can I just replace it with the big pulley that sits in its place on engines with the electrical fan set up? All the other accessories will stay at their place until I make the engine run and see if it works or not. Will I be able to use the same length belt in that case?
Also will this set up work with a LS2 or LS6 intake eventually? Or if I want to use that intake I REALLY have to replace the FEAD set up?
Thanks
Old Jul 29, 2011 | 07:38 PM
spacemanspif's Avatar
Just take the fan off. It unscrews from the water pump pulley.
Old Jul 30, 2011 | 08:26 AM
shrike's Avatar
Thanks, I was wondering if I can do that! It is the easiest solution!
By the way is that Spiff from Calvin and Hobbes?
