Ls1 cluster
Old Aug 3, 2011 | 02:46 AM
MikeyZ's Avatar
Default Ls1 cluster
Im transplanting a ls1 dashing another car And I cant get the dash odometer to light up It worked once now wont again I have the 2 grounds the purple and white and the orange hooked up am i missing something?
The speedo and tach max out and return and the volts read but the odom doesnt or any other lights
Old Aug 3, 2011 | 04:24 AM
itsslow98's Avatar
You need to hook up the grey wire, pin B9 on the pigtail to a 12 volt source. I wired mine direct to ignition so its lit all the time.
Old Aug 3, 2011 | 10:11 AM
the_merv's Avatar
Veteran: Air Force
You take that Gray wire and hook it into the Headlight Switch..that way when you pull the Markers it lights up the Gauges.
Old Aug 3, 2011 | 02:11 PM
MikeyZ's Avatar
I mean the actual numbers of the odometer
