Car porn alert: 'Orange Crush' - New LS6 w/ TVS Magna Charger
#61
so any issues with belt slip? I had a ton with my TVS2300 set up BUT I also have A/C. I made some changes to pulleys, added some guides and went to 8 rib, hope that helps. At the dyno now.
#62
You're talking the front accy belt right? Not the blower belt in the back? I bought the cog drive for the back - so no slippage there. Thanks, Jason.
#65
post pics, I will be adding a/c soon. I havent had any issues with my setup..3.6 6 rib front pulley, 1:1 rear...10psi
#66
I honestly really haven't laid the wood to her yet until I get it tuned next week.. I've rev'd the $hit out of it and rolled into it pretty good on the street, but havent noticed anything unusualy.. How can you tell if you are getting belt slip?
Well if it real bad it will jump off but if its semi bad you can see belt dust. Plus you will see it on the tune.
I run a 3.0 in front with IW over drive crank pulley and overdriven rears.
#67
How are things? I'll post some new pics soon, car is still at the dyno shop and I lost the old ones I have. I use the Kwik brackets but had to make my own pulleys, tensioner and guides. A lot of my work was due to wanting to run an 8 rib set up. Also alot of the need for custom pulleys was due to belt lengths available.
#68
Racinjason424
Wifey found the receipt for the s/c and I haven't seen her since.... She's probably at the travel agency trying to figure out how to get even with me.. I got a feeling I'll be somewhere tropical here soon..
#69
http://youtu.be/y44GNgfl2vI
Got her running.. I guess just unhooking the battery a couple times and letting it run long enough to re-learn? Seems to be running and starting fine now. Took her on a short trip around the block. Didnt lay the wood to it, but just a couple quick 1/2 throttle squirts - OMG wicked... :-)
TC
#70
Ill add another "Car looks incredible" to the list of hundreds already, but it really does. Hopefully I will be able to check it out at a car show or Woodward when you go, youll have to let me know when your down there for sure.
What trans is in the car BTW? Idk If I missed that being posted or not...
If you can, Post some interior and rear shots when you get a chance too please, Im sure they are just as good as the engine bay shots. The orange/white is great combo.
#71
