cammed 5.3 in 87 camaro. Take off issues
87 camaro wit a cammed 5.3, ported and polished tb, 4" cold air setup, ptc 2800 converter, 4L60e with all the hardened parts, 7.5 ls1 rear with 3.42 gear.
Cam is a Lunati 221/221, .558/.558, 114 lsa
Now my problem:
I went to the track to see what kind of numbers I would run. This was my first time on the track. I've run on the street quite a bit but was a bit nervous on the track the first couple times. The problem I have is that my time was a 14.8 in the 1/4. Before everyone starts ragging me saying I need a driver, that was not the problem.
Coming off the line, my car was pretty sluggish. It almost seem as though the gas was not getting to it for about the first half of the the 1/8th. Then all of a sudden it's like it was awaken and pulled really hard. So on the other end I'm pretty good. I'm just having problems out the hole.
My initial thoughts on this:
- Fuel pump doesn't have enough volume. It currently has a tpi pump in it. I installed this pump when I first built the 355 tpi motor. then swapped to a 5.3 and kept the pump since it had the pressure.
-Gearing. Maybe need more gear
- Timing. I have been messing around with the tune and I think it is good on down the line but may have some issues from take off.
If some of you guys could chime in and give me your thoughts it would be greatly appreciated.
I really feel as though I should be able to pull some mid 12's on motor.
Thanks in advance
Eric B.
Did you eliminate torque management junk in the tune?
Are you sure it's launching in 1st and not 2nd gear?
The guys have given you great advice thus far and I'd use it. Torque management could be fighting you, etc.
Get some scan data from a few street launches (in a safe manner, of course) and post it here. At a minimum, scan spark advance, banks 1 and 2 sensor 1 voltages, knock retard, LTFT for both banks, engine RPM, vehicle speed, MAP in KPa, and MAF airflow in gm/sec.
Please everyone post up what you find and I will do the same when I look at his car. Maybe we can find the answer between us.
T,
