EPS Cammed LQ9 in Christine ...Many Videos inside.
#42
#45
Hey man I love this car. I got a 84 with a LQ4 but I haven't dropped it in. I have motor mounts, fly wheel spacer (for 700r), and those same hedman headers you got. Any thing else u think im goin to run into while doin this swap?
#46
You will likely need a different oil pan and/or need to notch the crossmember. Once you get the electrical stuff sorted out, you will need someone to tune the "VATS" out of the ECM so it will start without a transponder key.
Aside from that, the rest will be normal engine swap stuff you will have to check, like trans cross member, exhaust, radiator with dual electric fans etc.
Car should move out nicely with a LQ4.
#47
KC Henry did u have to fab anything for those headers to fit. I got a LQ4 for my 84 caprice with the same headers u used and i dont see how that is gonna work. Any help would be appreciated
#49
His name on here and on the Impala SS forum is: aknovaman
Thanks, it sounds mean in person. Shakes cars and windows... I like it
#51
This my 72' Impala all original 64k miles w/ 400sb. I have a lq9 (05' Esky) I picked up with trans, harness, computer, etc w/43k miles for $1500. I'm really think about putting it in my impala. My 92' s-10 motor just bite the dust, so I'm thinking put the 400sb in the s-10 and put the lq9 in the Impala.
If I go that route I will definitely go l92/ls3 combo, cam, and 90mm TB. I found a local guy who does LS swaps in older trucks (because of the engine bay space), but he said he would do mine because it has a lot of room to work.
I have a few questions
Did you change any brackets/front Accessories for clearance. Did you have any clearance issues?
#53
Aknovaman is correct, we used F-Body accessories and the particular headman headers (4th Gen F-Body) we used were close on the pass side.
Thanks Anthony!
#55
#57
Anything that is "universal" fit normally doesn't fit perfect and it uses tiny itty-bitty allen keys to fasten, which is about the worst size/type fastner available in my opinion since they allllways strip out after the first use.
#58
im currently in the process of putting lq4 in my split bumper with the setup you have what kind of gas mileage do you think you are getting im wanting to be in the 20's with a 6 speed and 3:73 gears. im just amazed that big of a car runs that good with a cam swap i love the way it sounds nice job!!!
#59
Great to see ya still in the game, Henry! I always loved that car over on the issf, but I haven't been there in years. Glad I stumbled on this!
Tell Anthony that Crovo says hello!
#60
Seems like LS1Tech is much more performance orientated, so there have been more and more big car swaps popping up on here.
Nice Wagon btw!
